I've looked locally and online and can't find a dust cap for the front axle. Anyone have a part number or supplier? I searched the forum and couldn't come up with anything. You wouldn't think the part would be that hard to find.
It's actually the center cap that covers lock nut on the front axle. I have a 2WD. Without the cap the wheel bearing and grease and front axle ends are exposed to the elements.Do you mean the black plastic disc that fits over the axle shaft, close to the u-joint to keep the dirt out of the diff tube? Most trucks do not have them and they really don't do squat. If this is what you are looking for I can check the parts book for you if you really want them.
Thank you that helps me big time.
Here are two possible oem part numbers.
03634741 REG CAB 8 FT BOX and REG CAB CHASSIS WHEEL BASE 3, Med. Duty DODGE 2WD and heavy duty dodge 2wd
52007906 REG CAB 8 FT BOX and REG CAB 6.5 FT BOX, Lt. Duty DODGE 2WD
Also here is a Dorman part number for the non 4000lbs axle DORMAN Part # 13996 this part number was found on Rockauto.
