Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
Transmission Shifting Quesiton
This is a discussion on Transmission Shifting Quesiton within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
So since automatic transmissions are a dark art to me where a wizard controls the valves and a warlock the ...
Like Tree2Likes
  • 2 Post By dodge dude94
Reply
Old 01-15-2014, 07:20 AM   #1 (permalink)
jf5.9's Avatar
Ram Year: 1998
Engine: 5.9L
Question Transmission Shifting Quesiton
So since automatic transmissions are a dark art to me where a wizard controls the valves and a warlock the overdrive unit, and red ATF +4 symbolizes a blood offering to them both I have a question on what mine is doing.
First of Fluid Checks out ok. I have a small pan leak (when it gets a lil warmer ill be taking care of it) that I have stayed on top of level wise.
What its doing is it doesnt always want to get to overdrive. It doesn't struggle into overdrive it just wont go in all the time unless I get off the accelerator for a brief second. Doesn't always do it just sometimes regardless of outside temperatures or previous run time that day. Seems completely random.
Also sometimes when it does go right into overdrive I watch my RPM's drop in two stages say if I hit overdrive at 2200rpm it will jump down to 1700rpm and then down to 1400rpm. (cruising at 55mph i'm around 1600rpm on the factory tach.
Didnt know if this could be the sign of a eminent rebuild or what - just looking for answers. Any help is appreciated.
Finch
Sponsored Ad
Register to remove this ad.
__________________
1998 Ram 1500 4 x 4 5.9L Magnum, Rhino Lined Wheel wells and Rockers, Line-x Bed, Smoked Head lights, Tail lights and third brake light, Hughes Plenum Repair, and full tune up. Spectre CAI running on 127k mi - the tug for the jeep to places
jf5.9 is offline   Reply With Quote
Old 01-15-2014, 11:20 AM   #2 (permalink)
dodge dude94's Avatar
Ram Year: 1998 Ram 1500
Engine: 5.9 Magnum
Default
It could be as simple was your Transmission Valve (TV) cable being slightly too tight. I know when I get on mine it won't shift until I lift then get back on, but I don't mind it. lol
The two stages of RPM drop you're seeing is the transmission shifting into OD, then OD torque converter lock up.
__________________
1998 Ram 1500 4x4 QCSB, 360- ebay plenum, Cloyes 3028X, 14in Maggy, DIY CAI, DIY 50mm TB, TransGo shift kit, 285's, LED headlights, Ranch Hand Legend guardOctober 2014 - August 2015 TOTM Winner
dodge dude94 is offline   Reply With Quote
Old 01-15-2014, 12:11 PM   #3 (permalink)
jf5.9's Avatar
Ram Year: 1998
Engine: 5.9L
Default
now that makes sense - I dont mind it at all either - just like to make sure im not missing something going down hill - like i said auto trannys are a dark magic to me.
__________________
Old 02-10-2014, 09:55 PM   #4 (permalink)
Ram Year: 1998
Engine: 5.2
Default
My '98 has been doing something similiar this winter. On the really cold nights it sometimes refuses to go into overdrive. I havent checked the transmission fluid yet but it might be a tad low. Looking at draining and replacing the transmission filter when it warms up a little.
Segrat is offline   Reply With Quote
Old 02-11-2014, 02:26 PM   #5 (permalink)
Engine: 5.9 Magnum
Default
The transmission will not allow OD until the internal temperature reaches a set minimum of like 130 or something like that.
Merc225hp and jf5.9 like this.
__________________
Last edited by dodge dude94; 02-11-2014 at 02:39 PM. Reason: *Until, not under...damnit.
Reply
Tags
overdrive, torque converter, transmissions
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Transmission Shifting problems tdegan9470 Engine & Performance 5 10-16-2015 11:23 PM
2012 Transmission not shifting into reverse. jmlopez1969 Engine & Performance 1 06-20-2013 03:09 PM
Transmission shifting up marines83 Engine & Performance 3 04-24-2013 07:20 PM
transmission unusual shifting tuttledylan Engine & Performance 5 11-08-2012 11:57 AM
Transmission not shifting properly Mambosoul Tech Info 3 06-28-2012 03:03 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
