carcollector
- Dec 4, 2013
- 14
- 3
- 1998 1500 4x4
- 5.9
Hello - I have a 1998 Dodge Ram 1500 5.9 360ci 4x4 Automatic Trans w/4x4 floor stick.
I have No Spark and No fuel prime/run. The Fuel and Asd relays are Good and... when I jump the relays (87&30) I have 12 volts at coil/efi and fuel pump runs constantly. I have changed the distributor cap, cam sensor, crank sensor. I have tried unplugging crank sensor, cam sensor,tps, speed sensor and each O2 sensor while clearing the computer each time and still no response when you turn key to on at asd or fuel relays when key is turned on no clicking. there is 12volts at the relay and key.provides additional 12volt terminak so relays have proper power. Checked harness. and grounds and connector for vobvios problm. The check engine light comes on for a few seconds and goes out when you turn the key on. Using one scanner it had one asd code. It has good compression and only 120,000 miles.
what I haven't tried yet is disconnecting the trans to rule out an internal short to the shift solenoids. I also have not verified 5volt to TPS or map (?) But was planning that as my next shot.
me and a friend tested the wires from the pcm connectors and no open ground there that is not good. I am pretty sure it is not the PCM, or hoping its not... but I suspect a ground to the pcm or a chaffed wire. maybe a mouse got hungry and ate some wires .
I HAVE NO POWER AT THE "OXYGEN SSR" Fuse in the pdc (power distribution center) under the hood where relays are. Its. a 15amp. not sure if that's normal
Anyways i got it non running in a trade and need this truck for a driver its been sitting for weeks at a friends house 50miles away so i want to know what else to try on my third attempt.
I know this is a common worst case scenario electrical problems these trucks have but I can't seem to find any solutions I might have bypassed. I am a former Daimler Chrysler 5star Servie Manager. and ASE Mastertech/Auto Machinist so I have pretty much done everything I could except swap computer
