01Ram2500
New member here with a problem. Have a 2001 Ram 2500 4X4 with a 5.9L Gas V-8. I have owned the truck since it was new and it just turned 100K miles. The truck has been meticulously maintained and looks (and until recently) ran perfectly. It is bone stock. Here is a summary of the problem.
Took the truck in to the dealer in July 2014 and had the full fuel system service done (induction and injection) and a major tune up (plugs, distributor cap, rotor, and plug wires). Dealer also re-indexed the distributor.
Truck ran perfectly for about 2 months. Then I noticed the truck would accelerate moderately on its own without stepping on the gas. Usually did it when warm at highway speeds. Also, at times, when I took my foot off the throttle, the truck would continue on as if I had maintained pressure on the throttle.
I took the truck back to the dealer in Sep 2014 and they replaced the throttle position sensor (TPS). Problem still existed and in fact the at one point, the truck tried to run away with me in a parking lot as if I had stepped hard on the throttle even though I barely touched it. I took the truck back to the dealer again and they replaced the Idle Air Control Motor (IAC). Could not find anything else wrong. No codes thrown at any time.
Well as of now, the problem still exists. Not sure what to do at this point but the truck is potentially dangerous to drive. Does anyone have any idea what might be causing the problem??
Dave
Dave
