please help
boarderkidd11
i was driving my truck today and i was going p a hill when i had the gas all the way down my rpm just kept dropping so i shifted down and it still happen and the my engine light came on with the code p 0123 what should i do?
boarderkidd11
boarderkidd11
so if i change that do you think that my problem climing up the hill would be fixed?
ramthis9501
Oklahoma
5.2 V8
Just an idea, but maybe the cat might be clogged... that's what I'm thinking with my truck right now, it lowers overall engine performance and I read a few things that said the exact thing that you are and they had a clogged cat
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Check your cat to see if its glowing after you have driven it, then you will know if thats plugged or not
boarderkidd11
boarderkidd11
so if it glows its clogged. am i correct?
The Assassin
B-more careful, Murderland
Do you have a code reader, or a tuner that you can hook up to it? Then cross reference the code. But I am 99.9% sure its for the TPS. It might not be a bad idea to do a full tune up.
txbass06
NE Texas
5.9 Magnum
Yes. There would be no other reason for it to get hot enough to glow
P0123 Code - Throttle Position Sensor/Switch A Circuit High Input
boarderkidd11
boarderkidd11
it is the tps i just looked the code up. i also have all new wires,plugs,cap and rotor i just put them in about 3 weeks ago when i bought the truck
boarderkidd11
boarderkidd11
ok i will also check the cat next time i drive it
txbass06
NE Texas
5.9 Magnum
Did you ever swap out the tps?
boarderkidd11
boarderkidd11
yeah but i had it in upside down so i went to go switch it and went to pull off the blug the thing sprung open
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Yup mine did that too. Need to go pick up a new one. They aren't that expensive. I tried to repair mine after it popped open yea that didn't work. Best to pick up a new one.
boarderkidd11
boarderkidd11
the one that broke was brand new but i picked one up today. appearently they have a warranty
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Yea usually they do at least from my local store they do. Did you get it replaced??
boarderkidd11
boarderkidd11
yes i did turns out they gave me a faulty one in the first place
BigMike005
Miami, FL
On the clog cats, just put your hand over the tail pipe and feel if there is pressure from the exhaust fumes......if not u got yourself some clogged cats
