clownprince
- Sep 17, 2014
- 70
- 15
- 1997
- Magnum V8
Finally got under the new Ram I bought, 99 1500 5.2 4X4, and found some stuff I was unsure about. The first picture is where the rear driveshaft leaves the transfer case, looks like its been shifting in and out. Possibly shaft movement from bad pinion bearing? I do get the "clunk" going into reverse.
Also the fluid that was gathering in the same area was black so I'm sure I need the transmission serviced, not sure if it's ever been done.
What do you guys recommend?
Also have some what look like holes in the back of the front differential, do these look normal?
