I just bought my 2015 Big Horn. I absolutely want to do this.
Questions:
*Are the actual switches removable?
*Can the switches be moved to different positions?
*I'd like to move all the current switches to the top row and make the bottom row all "Aux".
* Are the unused positions "dead-ended" in the harness?
1. After watching one of the videos posted above, yeah the switches are removable with a little work
2 & 3. From the same video, it looks like it they can be moved around a little. However the top row and bottom row have different shapes to them so they may not be able to swap with each other. Also the ones on the end that curve around probably wouldn’t swap either. Also you’ll have to do some wiring to make sure the buttons you change the positions of match up with the wiring
4. It also looked like from the video that every button (including the unused boxes) have the circuitry behind it, so I would imagine those circuits have to output somewhere
Thank you to the guy who posted those videos earlier. It looks to me like the only difference in part numbers between all these switch banks is the faceplate and buttons—all the electrical appear to be there no matter the part number. Since these switches are so easy to take apart and swap buttons, I doubt it would be too hard to make some custom buttons with some fab work
Have one of you guys taken apart your old switch bank without the aux buttons? Im kinda wondering if the circuitry is behind those as well
