4th Gen DIY How To: Fogs on with the High Beams
This is a discussion on How To: Fogs on with the High Beams within the 4th Gen DIY forums, part of the Tech Info category! Register to remove these ads. It's free!
I ordered a kit from this website, but after seeing how easy it ...
01-15-2012, 10:36 PM
#1 (permalink)
Ram Year: 2010 Sport 4x4
Engine: 5.7L
I ordered a kit from this website, but after seeing how easy it is, I figured I would do a write up for those wanting to do this. The kit is nice, everything is included, but this could probably be done with $10 or less in materials from a local auto parts store.
Link to what I bought:
MrTailLight.com Online Store
What's included in the kit that you would need:
(1) standard relay
(2) wire taps (or t-taps)
(4) pieces of 16 gauge (or whatever you want to use)
(1) inline fuse
a few zip ties
Start off with the relay, I mounted it to the same bolt that holds the back of the headlight in place. That done, I ran the ground wire to the small bolt that holds the bumper to the fender. You'll only need about 6" or so from the relay to that bolt. I ran power to the battery with an inline fuse. Run a wire from the relay to the white wire with green stripe that goes into the high beam housing on the back of the headlight. I used a t-tap here. Then from the relay, drop a wire down inside the fender to the driver's side fog light bulb. Throw a t-tap on the driver's side positive to the fog light bulb (I tapped it to the connector that the bulb plugs into). I used a few zip ties to keep things neat.
That's all there is to it. As far as functionality, high beam works with the fogs as well as lows. Even if the fogs are off, when you click the high beams, the fogs kick on as well as high beams. The parking lights and headlights still function as normal.
I don't have any pictures as it was after dark when I finished tonight, but it's really pretty straight forward. The biggest hurdle was just knowing which factory wires to tap into.
__________________
Interior: Color matched trim, complete LED swap | Exterior: 5% limo tint, black emblems, black painted headlights, 20" Fuel Hostages, 37" Mud Grapplers, tow mirrors, tow hooks | Performance: Yukon 4.56s, Vararam Intake, DiabloSport Trinity, Raceland USA e-cutout, BT Catch Can | Lift: 6" Pro Comp lift, 1.25" RCX body lift, Bilstein 5100s set at 2.8" | My Pictures
01-15-2012, 10:53 PM
#2 (permalink)
Ram Year: 2011
Engine: 5.7L Hemi
interesting I'll have to buy the relay and do this myself.
01-15-2012, 10:56 PM
#3 (permalink)
Site Administrator
Ram Year: 2010 1500 Crew
Engine: 5.7L
I like this, but I don't want my fogs on all the time.
Well..........maybe. LOL
__________________
RamForum.com Administrator / Preferred Vendor
RetroShop.us - Custom Automotive Lighting Specialists / Fukken Wax - the BEST waterless wash & wax on the planet!
☼ the Bitch ☼
2010 Ram 1500 Crew - Silver
Hemi / 4x4 / Sunroof / Bucket Seats / Alpine Surround Sound / Adjustable Pedals / Mopar T-Handle Shifter
20" Black XD Hoss Wheels / 295/60/20 Nitto Trail Grapplers / HBS 2" Level Kit / RCX 1.25" Body Lift / Bestop PowerBoards
SC Vivid / Volant CAI / TYC v6 eFan / Raceland Cutout / Bakflip G2 / Bed Mat / Stubby Antenna
Custom Painted and Retro'd BiXenon Headlights & Fogs / LED Tails / Debadged & Custom Front & Rear Badges / Mufflex 5" Exhaust Tips / Viper 5701
Kenwood DDX319 / Fiberglass 10" Sub Box / Kicker 1000.5 / Kicker 10" CVX
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
01-15-2012, 10:57 PM
#4 (permalink)
Ram Year: 2011
Engine: 5.7L Hemi
throw a switch inline with the wire that triggers the relay so you can make it an option. I would
01-15-2012, 11:01 PM
#5 (permalink)
Engine: 5.7L
The fogs aren't on all the time this way.
__________________
01-15-2012, 11:29 PM
#6 (permalink)
Site Administrator
Engine: 5.7L
when I redo my fogs I'm going to do this.
4 projector high beams at once bitches.
__________________
☼ the Bitch ☼
01-16-2012, 06:39 AM
#7 (permalink)
Ram Year: 2006
Engine: Cummins 5.9
In the 3rd gens, this was a TIPM setting that could be modified with the bullydog, I assume it should be able to be done on the 4th gens by your dealer / programmer / etc..
__________________
2006 - RAM 3500 Megacab - CTD - K&N CAI -LightForce Driving Lights - KC LED Driving Lights - ReTrax Bed Cover - Inferno Red
* HIDs should not be installed in stock lights (Reflectors) - Use only HID Projectors. *
-Cummins Turbo Diesel Club - #10
-Little Red Wagons (Red Truck Club) - #Do we have #s?
01-16-2012, 07:43 AM
#8 (permalink)
Ram Year: 2000
Engine: 5.9 360
just a warning about these kits the wire taps (or t-taps) can cause a break in your wires. they will also over time corrode and make your lights stop working
my suggestion to solve this would be to cut your wires and splice every thing back toghter and use lots of wire grease and heat shrink
other than that the kit is awsome just be careful if your use the wire taps (or t-taps)
01-16-2012, 07:51 AM
#9 (permalink)
4th Gen / Site Mod
Ram Year: 2011 1500 Sport Quad Cab 4x4
Engine: Hemi 5.7
awesome info Kevin...thanks
__________________
RamForum.com Moderator
01-16-2012, 11:50 AM
#10 (permalink)
Engine: 5.7L
This has come up in discussions before. Dealers won't do it as it's some kind of safety violation (at least that's what I've been told) and no programmer can do it as of now.
Thanks for that info. If something stops working, I'll know where to start trubleshooting.
No problem.
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
