Lifts and levels
joeygster
Ancaster, Ontario
Could I get you to measure your truck from the highest cab point to the ground? I'm trying to figure out if I can still fit in my garage door with a 4" lift?
Check out my build thread. There is a lot of info in it on this issue.
http://www.ramforum.com/f38/finally_2016_ram_1500_sport_crew-85380/
Specifically, check the following posts within that thread.
Post 36: Pics of Ram fit under garage door opening.
http://www.ramforum.com/1319683-post36.html
Post 68: Pic of the roof puck
http://www.ramforum.com/1350776-post68.html
I’ve got the puck antenna instead of the shark fin.
Mine fit into a garage with a 7' door & weather stripping that leaves me an opening of approximately 82 3/4". Plus my driveway slopes up to the garage so that will help too.....
I also changed the open check on my garage door and gain a couple more inches for the door so it was raised above my weatherstripping.
I measured for you, but I’m running 275-65-20’s for the winter & they are almost an inch shorter in diameter than my 35’s.
That being said….right now my truck sits at approx. 80” tall including the puck, so with the 35’s I’m at approx. 81” tall.
that_blue_ram
London ON
2016 Ram 1500
Levelled on Bilstein 5100's set to 2.8".. plus 3" performance accessories body lift.. rolling on Falken Wildpeak MT's 35/12.5/17 mounted to BlackRhino Sidewinders 17/9 w/ 0 offset.
f775f9062637d066c6019dc14c5bd631.jpg362fee8f27ca4909367193fc176e59fb.jpge961e781ada5287e15dcd0810ed31f57.jpg
If it helps I measure 81.5"... stock rear end, the 1.5" rear coil spacer goes in tomorrow.. may increase overall height by a touch
Jershipe
Monroe Michigan
4 inch rcx. Bilstiens up front at 1.4,rear 1.5 spacer,35/12.50's. Fits under 7ft door with about 2 inches to spare. No shark fin. Mine is flat0591dbbea88fe718f6ff89fdfd922615.jpgbd198a2df8ac9652f1ad3c70b38d7d4e.jpg8cdc369b6d4acbe9ccb0dde258f437b0.jpg
mpittman
Indiana
2015 Big Horn Crew Cab
Do the Bils add 1.4" on top of your 4" lift for a total of a 5.4" lift in front?
Jershipe
Monroe Michigan
Yes. Pics aren't very good. Weather hasn't been great. Only has 3/4 spacer in the back in those pics. Just changed it yesterday. It was about a half lower in the back. Like a little rake
mpittman
Indiana
Cool. I'm looking into adding a 4" front lift, and 2" rear lift to level it, but I have the shark fin, so I still need it to fit in the garage. But, if you actually have a 5.4" lift on the front, with 2" clearance on the door, I should be good? Hopefully?
mooreman21
Going to the dealer to find out if it's possible to put 2500 rear coils in my 1500. That'll give me 2.5 inches in the rear and then I can out a 2.5 level in the front
I've been curious about that too. Did you ever find out?
goodguy11
goodguy11
HEMI 5.7
Oddly enough. They said that the front end i can literally swap one for another. However the rears they weren't sure about. While they were lookin at the truck I went roaming around the truck lot and compared a 1500 rear coil to a 2500 rear coil and it was pretty obvious to me that the mount on the rear axle was definitely bigger on the 2500 than the 1500. Next time I'm gonna find out if they can do some fab work to make it work with voiding any warranty
goodguy11
goodguy11
HEMI 5.7
Anyone running a pro comp 4inch on the 1500?
