Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Tech Info > 3rd Gen DIY
Sponsored Ads
Register to remove these ads.
3rd Gen DIY
Spark Plug Change DIY
This is a discussion on Spark Plug Change DIY within the 3rd Gen DIY forums, part of the Tech Info category!
Register to remove these ads. It's free! OK guys, here it is. A DIY on how to change the spark ...
Reply
Old 10-30-2010, 08:03 PM   #1 (permalink)
OlDirtyJohn's Avatar
Ram Year: 2004 Quad Cab 2500 *Sold*
Engine: Hemi 5.7
Send a message via AIM to OlDirtyJohn
Default Spark Plug Change DIY
OK guys, here it is. A DIY on how to change the spark plugs in your 3rd Gen Hemi Ram.
What you will need:
16 New Spark Plugs (preferably copper)
Basic Ratchet set
A few different sized extensions
Spark Plug Socket
Anti Seize
To start, park your truck, let it cool off, and open the hood.
Note: Under my hood is dirty, dont let yours start looking like this.
Next, take off your intake, and disconnect your battery.
I like to start on the passenger side plugs first, because they are easier. Locate your first coil on the passenger side, and remove the 2 bolts holding it in place with a 10mm socket.
then simply pull out the coil and also the plug boot for the plug next to it. (note, i have shorty wires, so mine might look different than yours, the process is still the same though)
Now, attach your plug socket to an adequate length extension, and remove the plugs.
Now that you have the first two plugs removed, grab your 2 new plugs, properly gap them with a gapping tool, apply a little antiseize to the threads, and put them in in the exact opposite as you took the old ones out. once the plug is snug, tighten it down approximately 1/6 of a turn. replace the coil, and tighten that back down.
Now, move on, and do the same exact thing you just did to all the rest of the plugs.
Once you get to the hard to reach plugs, you will no longer be able to use your 1 long extension. Instead, use several smaller extensions, and place them into the hole one piece at a time.
Now for the last 2 pairs of plugs, the dreaded 4 under the brake booster. OH NO! Actually, its no big deal. Just take off both coils, and the coil next to them. Be sure to keep them in order and dont mix those 3 up. Then just slip your tools one piece at a time into the spark plug hole. Socket first, then a medium length extension, then your ratchet. Loosen the plug, remove the ratchet, pull up until you can get a finger on the socket, remove the extension, then pull the socket with plug attached out of the hole. No big deal.
In the above pictures, you can see that I have a full sized 3/8" ratchet under the brake booster. I have plenty of room to work, and to turn the ratchet. Those last 4 plugs may look like a daunting task, but as long as you put one piece in at a time, its a piece of cake.
Total time for me to complete the entire plug change was under 2 hours.
__________________
2000 Honda Inspire (Acura TL) 2.5l v6 auto, right hand drive. tinted, lowered, debadged, basically riced out to the max!
1996 Mitsubishi Delica Space Gear. 4x4 3.0l v6, bull bars front and rear, side steps, full skid plates.
OlDirtyJohn is offline   Reply With Quote
Old 10-30-2010, 09:53 PM   #2 (permalink)
OklaHemi's Avatar
Ram Year: 04
Engine: new age hemi
Default
nice write up. its about time to change mine
OklaHemi is offline   Reply With Quote
Old 10-30-2010, 10:01 PM   #3 (permalink)
onebadbee's Avatar
Ram Year: 05
Engine: 5.7
Default
pulled my over flow pulled my fan took off my nightmare of a set up intake
had the plugs changed gapped everything in 3 hours
__________________
12.69 1/4 1.66 60 ft no heads no nitrous no chargers just a cam and some bolt ons
Dodge Ram Forum | Ram Forum | Ram 1500 Forum | Dodge Truck Forum | Dodge Ram Parts | Dodge Ram Accessories | Dodge Ram Performance
onebadbee is offline   Reply With Quote
Old 10-30-2010, 10:38 PM   #4 (permalink)
blk05hemi's Avatar
Ram Year: 2005
Engine: Hemi 5.7
Default
Great DIY
__________________
05 Dodge Ram 1500 2wd QC 5.7 Sport Lonestar 3.92 gears 75,000 Miles
MODS: SC 3865 / Pacesetter LTs ORY No Cats / 18" Flo-Pro / 4" CAI / 20" KMC Badland Rims 9.5 / Toyo OC A/t 305/55/20s 3" Spacer / Bilstein Shocks / Morimoto Projectors 8000K HIDS LED Tinted Tails-3rd / Apline 9886 Headunit / JL 12w3-FoxBox
blk05hemi is online now   Reply With Quote
Old 10-31-2010, 01:22 AM   #5 (permalink)
Engine: Hemi 5.7
Default
thanks guys! just trying to help. maybe now some guys who were on the fence about changing their own plugs will man up, and get to work. screw giving our hard earned money to the dealerships!
__________________
Old 10-31-2010, 10:44 AM   #6 (permalink)
Banned
Ram Year: 2004
Engine: 5.7
Default
Great writeup. It shows that it really isn't that hard to change the plugs on these engines.
Off_Road_Teacher is offline   Reply With Quote
Old 10-31-2010, 11:09 AM   #7 (permalink)
Banned
Ram Year: 2005, 2009
Engine: 5.7 Hemi
Default
Nice write up. I got to change mine in a few weeks
shadow11 is offline   Reply With Quote
Old 10-31-2010, 12:49 PM   #8 (permalink)
Trupiano's Avatar
4th Gen / Site Mod
Location: Hometown : Puyallup,WA Stationed : Little Rock, AR
Name: Steven [TRIP/TRUP]
Ram Year: 2011 Ram 1500 4x4 Hemi Crew Cab Sport
Engine: 5.7L HEMI
Default
Here's a pic to help, if anyone gets confused reconnecting spark plug wires/coils.
__________________
RamForum.com Moderator
Exterior: Black Grill l Debadged l Tint l Fukken Lights 5K H/F l Stubby Antenna l Custom Painted Mopar Stripes l Tinted Tails l Access Tonneau l G/F 2/3 Drop l 22' boss 330
Interior: Radar Blendmount/Hardwire l TomTom Hardwire l WeatherTech Mats l Lockpic l B/U Camera
Performance: 14' Magnaflow l Res Delete l Sonnax Line Booster l BT CatchCan l Volant l 306HP/331TQ DYNO VIDEO
Trupiano is online now   Reply With Quote
Old 10-31-2010, 01:20 PM   #9 (permalink)
KGBIGCOUNTRY's Avatar
3rd Gen / Site Mod
Ram Year: 2004 RCSB/2005 QCSB
Engine: 5.7 / 5.7
Default
A small magnet to pull the plugs out can be easier then trying to keep the plug in socket if you dont have a socket with the rubber boot. Good write up there bud.
__________________
Its Tweaked & Twisted
Crazy Spartan on a 112lsa Thumping It, PWR Heads Opening It Up, Coated Pacesetters Doing The Rest, Tuned by Spooldu with DSP
Powed and Tuned by King Motorsports
KGBIGCOUNTRY is offline   Reply With Quote
Old 12-11-2010, 04:44 PM   #10 (permalink)
Ram Year: 2006
Engine: 5.9 24v ctd
Default
That was a great right up happy to know that it will be fairly easy to change mine. Thanks
04hemi is offline   Reply With Quote
Reply
Bookmarks
Tags
changing spark pugs, more power, spark plug change, tune up
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
DIY: Differential Fluid Change OlDirtyJohn 3rd Gen DIY 10 03-07-2012 01:44 AM
Spark Plugs OlDirtyJohn General Discussions 20 08-30-2011 12:50 PM
I want to change my 4x4 shifter know fatwombat Interior 16 03-17-2011 10:43 PM
e3 spark plugs 5.7 ike43 Engine & Performance 16 08-22-2010 08:49 PM
Time For A Change MOPAR78 General Discussions 8 07-25-2010 01:42 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
