Go Back   DODGE RAM FORUM - Dodge Truck Forums > Preferred Vendors > Retro Shop
Retro Shop
Passenger bulb out
This is a discussion on Passenger bulb out within the Retro Shop forums, part of the Preferred Vendors category!
So this is a recent issue although it could go back to when I first installed. My passenger bulb has ...
Reply
Old 02-24-2017, 08:03 PM   #1 (permalink)
Andrew09HEMI's Avatar
Ram Year: 2014
Engine: Hemi 6.4
Default Passenger bulb out
So this is a recent issue although it could go back to when I first installed. My passenger bulb has always been dimmer than the driver and this evening it went out. If I turn the truck off then back on again it'll light up very dim then go out. I haven't taken the assembly out yet to determine if its wiring issue but hoping you could shed some light. Thanks!!!
Sponsored Ad
Register to remove this ad.
Andrew09HEMI is offline   Reply With Quote
Old 02-24-2017, 08:16 PM   #2 (permalink)
Ram Year: 2004
Engine: hemi 5.7
Default
My friend with an 01 Ram had a similar problem. Bulbs burning out and dim. We discovered a wire in the harness lost the coating and was shorting from moisture. He thoroughly covered the wire with electrical tape and no issues since
bhonshell37 is offline   Reply With Quote
Old 02-24-2017, 09:19 PM   #3 (permalink)
Ram Year: 2014
Engine: Hemi 6.4
Default
I'll take a look tmrw but this is kinda why I hate aftermarket stuff. Not saying I don't like the look and brightness but having to worry about it going out and not being able to just swap a bulb at a store is not fun
Old 02-28-2017, 09:29 PM   #4 (permalink)
Ram Year: 2016
Engine: 3.6
Default
Sounds like high resistance in the wiring, not allowing proper voltage to to the bulb. Definitely check your wiring, if it is all good and corrosion free, check your plug, they will burn and melt, not allowing good contact. Also ohm out your bulb. It could be bad also
dzltek is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Front Passenger turn signal bulb! Skipper Exterior 0 04-09-2016 06:30 PM
Passenger Air Bag markmass Interior 0 08-15-2013 10:32 PM
HID bulb help! DBrown21 Exterior 18 01-27-2013 05:16 PM
Passenger hub GhostRam94 General Discussions 6 05-13-2012 11:26 PM
passenger air bag blackout11 Interior 5 09-09-2011 10:12 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
