What's your thought on buying a new 2023 from the rust belt?
Weekiman
WEEKI WACHEE
I found one optioned with everything I want. What kind of corrosion will it have after going through one or two winters?
Racer9
Erie PA
Nothing to worry about. Sitting with snow falling on it and then melting off is no worse than being rained on.
If it had already been driven 10k in the winter on salty roads, then you might have an issue, but a good underside cleaning and oily rust preventative would have fixed you up.
dhay13
I wouldn't worry about it. Even a couple of years in the rust belt still look very good
W
Weekiman
WEEKI WACHEE
Do a visual inspection, but if it is a left over they have maintained it. I wouldn't worry about some bolts or such with a bit of corrosion.
Nice! It has ten miles on it so it has probably been test driven once. Hopefully not on salt.
zrock
canada
ummm what are you going to do buy it and store it so it does not rust?
markabby
kentucky
i just mentioned thee bolts as a reference to see if anything would begin rusting.
GoWhite
USA
I live in north jersey. I’d buy it if the price is right. Rust is a fact of life for me.
You should look at some of the sale prices right now! Tradesman in Houston are going for $30-35K. I picked up a 4x4 crew cab 3.6 for $32k +ttl over the weekend. Autonation in Spring, and Mak Haik CDR each have about 200 1500s in stock and at big markdowns.
W
Weekiman
WEEKI WACHEE
I looked they do have some great deals. Thanks,
GoWhite
USA
While I was there on Saturday, they were selling a lot of vehicles out of state. Ive heard that Ram wants to send them another 100 vehicles this week...
