engine swap
  1. D
    2010 Dodge Ram Seized Need to Swap Out
    Hi, My engine seized on my 2010 Dodge Ram 1500 5.7 Hemi. Oil Sensor had gone off, swapped the sensor at the parts store thinking that was the issue. Needless to say the truck stalled one mile before getting home. My guess is the oil pump went out, then after my inadequate response, the engine...
  2. H
    Eco diesel to Hemi swap, looking for info.
    Hey guys I need some help on what's required to swap out an Eco diesel for a 5.7 Hemi in a 4th gen Ram. I've scoured the web but haven’t found any information on it yet. Has anyone ever done this before? Here's the back story (before everyone starts chiming in to say "just trade it"). I have a...
  3. C
    Engine swap noise
    I just bought a 2003 Dodge Ram 1500 4.7L and it had an engine swap with a 2005 4.7 engine. I have driven the truck before the engine swap and the engine sounded good and powerful. Now it sounds like “windy”. The fan is the loudest thing I hear instead of a strong V8 engine. What can the issue be?
  4. L
    Engine and transmission swap
    My 2009 hemi 5.7 engine gave up! Found a newer engine and transmission, transmission is from a 2014 so its an 8 speed transmission and mine is a 6 speed can that be easily swap? Thanks for your help!
  5. C
    2013 5.7 vin T into a 2010 5.7 vin T will it work?
    I HAVE A 2010 RAM 2500 5,7L VIN T THAT NEEDS A ENGINE. I ALSO HAVE A ENGINE FROM A 2013 DODGE RAM 1500 5.7L VIN T. I AM TRYING TO MAKE SURE THE ENGINES ARE COMPATIBLE. THE PARTS LISTINGS FOR ENGINE SAY 10-12. DOES ANYONE KNOW THE DIFFERENCE AND CAN I MAKE IT WORK?
  6. L
    Engine swap
    Hey Dodge fam, So my Dodge motor blew and I need to swap a motor asap. I work in a junkyard so I can easily get a motor. Now the issue is it's hard for us to get a ram just like mines. I have a 2003 1500 3.7 V6 mag. A 94 Dakota V8 mag. Came in and I wanted to know if it'll fit and if it does...
  7. A
    2002 Dodge Ram 1500 3.7 V6 engine to a 6.4 swap?
    Hey guys so I'm new to this forum stuff but seeing as how there are so many interesting threads here and a community of people willing to help out in those threads I want to give it a shot. That said hopefully someone reads this, so I'm getting a 2002 3.7 Dodge Ram 1500 regular cab and I want to...
  8. CLEARBLU
    2010 4.7L imploded...to Crate or not to Crate?
    Greetings All. (sorry for the essay) I've been a long-time lurker on here ever since buying my 2010 Ram 1500 SLT 6 years back. I love my truck and it has been pretty carefree up until now. I've got about 157k miles on it, and its really only given me trouble with the front brakes, and the water...
  9. M
    06 Ram 5.7 to 03 Ram
    I am new and have a question I have a 2003 Ram 5.7 that dropped a valve and destroyed engine. I just purchased a 2006 Ram with 5.7 rollover truck with low miles that runs great for engine and transmission. I pulled motor and transmission out of both and if I install 06 engine with the 06 harness...
  10. E
    Cab or engine swap easier?
    I have a 2002 4.7l dodge ram, the engine went out, so I bought a wrecked 2003 5.7l Hemi thinking about doing an engine swap. But I want to know if a cab swap would be less of a headache than an upgraded engine swap. What do you guys think would be best?
  11. S
    Removing Intake Manifold - 2007 5.7 Hemi
    Hi fellows, I need to swap my engine... All easy so far, but now I want to remove the intake manifold. Do I have to remove the injectors first? How many bolts are holding it down? I Have an lpg system installed, can i remove it still installed on the plastic manifold? Cheers for any help
  12. D
    Mechanical Differences Between 1500 and 2500?
    I have just purchase a rolled 2003 1500 parts truck so I can put the low mileage 5.7 hemi into my 2003 2500. I understand the major differences (frame, axles, suspension, ride height and quality), but my question is, what are some of the smaller mechanical things you might not think about...
  13. D
    2011 engine and transmission swap questions.
    I drive a 2011 Dodge Ram Laramie with a 5.7 hemi with 220,000 on. Lookin for answers and help, over the course of a year I’ve had to replace and transmission and I’ve spent roughly $1,000+ on engine work to try figure out why I have a bad cylinder 1 misfire, changed plugs, coils, took it to a...
  14. O
    older engine in new truck
    Hi, Thanks for reading. Here goes my dilemma: Can I put a custom rebuilt older Dodge engine in a new Dodge ram pickup truck? Yes I will fabricate whatever mounting and adapting hardware, etc. is required, the reason I want to do this is I want the plushness and safety of the new truck with a non...
  15. S
    Ram 3rd Gen 1500 5.0 Engine swap
    Hello dodge fam! This is my first post here and I'm brand new to the community. I have a 2002 3rd Gen Ram 1500 RWD with a 4.7l and an automatic transmission. But alas at 350000km The engine caved on me. Anyways I have a fuel injection 5.0 In a 1990 Mercury that I'm going to swap into the...
  16. TScottinTx1
    Engine Swap Help
    Swapped out 5.7 Hemi out of my 2014 Ram 1500 and replaced with another 5.7 out of a 2017. Everything went in fine until got the transmission. Can't get it to line up to bolt in. Looks like the torque converter may be preventing it from flushing up against the motor. Does the converter need to...
  17. Tteal235
    Brace yourselves, TAXES are upon us!@!
    Alright gents, I've mentioned this before about swapping my 5.7 to a 5.9. Since then, I have done a lot of research. I've narrowed it down to the donor I want and type of cummins I want. I am going with a 94-98 12v. I am aiming for a manual, but if I cant find what I want to the T, ill be happy...
Goodie1990
