tail lights
  1. T
    Water in tail lights
    I noticed a strange waviness in the reverse lighting as seen through the backup camera. As I was backing up in a parking lot a bystander told me there was water in my reverse lights. The water caused one of the bulbs to break. Has anyone else ever had this happen? Does anyone know how the water...
  2. YITAMOTOR
    Introduction From YITAMOTOR
    Hello everyone, we are Yitamotor, which is one of the best shops offering auto parts, specializing in floor mats, bumpers, tonneau covers, running boards, storage boxes, headlight assembly, LED light bars, etc. mainly for Dodge Rams, Jeep Wranglers, Ford F-series trucks, and Chevy Silverado...
  3. T
    Factory Projector Headlights & Factory LED Tails (change the housing/lights - not a bulb question)
    I have a 2021 Warlock. It comes stock with projector headlights and LED tail lights. Most of the aftermarket housings/lights out there say they do not work with factory projector headlights or don't work with factory LED tails. My guess is it is simply because of the wiring harnesses that are...
  4. jacoblane216
    Tail Light Color Code
    I’m trying to help this feller out, he has a 2002 ram with the 4.7 if that matters. He said he’s trying to do some custom tail lights himself and he can’t find the correct color codes online for what he’s looking at. He needs the color codes for left and right 2002 ram 4.7, he says he has...
  5. P
    2020 Ram 1500 tail lights out
    I've seen a lot of ppl on here with the same issue. I have no rear tail lights, but all other lights work, I have checked all my fuses, bulbs, and pins with my meter, like new, no corrosion all fuses have continuity and all the pins that need ground have ground and pins that need voltage have...
  6. R
    Factory LED Package Compatible Tail Light Recommendations
    2022 Ram 1500 Laramie 5th generation (new body style, not the classic still offered...) with the Factory LED light package. I'm having a heck of a time finding compatible tail lights. I'd love the factory midnight editions like on the last truck, but they're either sold out thru Mopar sites, or...
  7. E
    Left Rear Turn Signal light indicator not working
    So annoying as the light is working fine. Has anybody else had this issue? Maybe it is a loose connection?
  8. A
    LED parking light not working (light is good)
    I have a 2016 Ram 3500 Diesel. The passenger side taillight stopped working. I can switch it to the other side and it works so I know it is not the light itself. Turn, and brake lights still work. Have traced the wire all the way up to the connector behind the drivers tire and have a signal...
  9. T
    Looking for NOS taillights for my 2000 Sport
    Good day. I have a 2000 Sport model Dodge Ram. I am trying to locate new old stock tail lights and break light. Do any of you know of a source?
  10. D
    Help! Tail lights not working!
    I have a 2017 Ram 1500 and my rear running lights are not working. I have LED rear light and both left and right side are out. brake and turn signal are working on both sides. and just make sure it wasn't my tail lights. i installed them on my dads similar ram truck and they work just fine on...
  11. B
    Tail lights
    I recently bought the morimoto tail lights and having an issue with the passenger side tail light. I reached out to them and unfortunately they don’t work with stock led harness yet. Was wondering if anyone else bought them that had stock leds and what they did to get it to work.
  12. David Janes
    Tail Light Change
    Hello, I have a 2013 ram 1500 tradesman. I bought a set of recon tail lights off a guy that took them off his 2013 and he said that the connectors might be different for the brake light, turn signal connector. The connector in my truck is has 3 tails and is more oval and the connector on the...
  13. OEDRO
    Buy this bundle and save 40%
    Today we will introduce a bundle! 2017 ram headlight+ led tail light. Bundle price: $101.39 Save 40%!!! Black Quad Headlights Assembly for 2009-2018 Dodge Ram 1500 2500 3500 Brake LED Tail Light for 09-17 Dodge Ram 1500 2500 3500 If you have any question about our products...
  14. Kamren
    2005 1500 SLT Blinker Issues
    Recently, my truck started having an issue where my left blinker stops working any time my brake, tail, or reverse lights come on. If I use just the blinker, then it's fine, but when I turn on any other light it goes out only in the back. The front continues working, but blinks quickly. I pulled...
  15. Baseballer5dt
    Aftermarket Tail
    I recently purchased smoked akkon led tail lights and Im experiencing hyper flashing from my dash and mirror signals, but not the tail lights. All lights work even though I get a message saying rear signals are out. Any suggestions on fixing this?
  16. Cblsurfer
    Factory LED Tail light replacement option in Canada
    Hi All, Yesterday i was unable to avoid a rubber bungee with the S hooks while driving back from work and got some damage on the truck... busted step pad, a few dents, a punctured tire and....busted tail light... first few items are minor... tail light need to be replaced. Called the dealer...
  17. R
    Rear Tail Light Out
    Now I know everyone likely wants to tell me to check the bulb and the socket. I did both of those, but thanks for hoping for the simple solution. I did too. Truck: 2010 Ram Laramie 3500, 4x4, 6.7 Diesel What happned is this. The rear passenger tail light AND the passenger side light at my...
  18. 0
    Aftermarket Headlights
    I got a 2018 1500 a couple months ago, and I absolutely love the truck. However, the OEM (standard model - NOT factory projectors) headlights are almost dangerously dim. If anyone has any suggestions for headlights, it would be really helpful. I'm looking for black/smoked headlights that are...
  19. M
    2014 Ram 1500 Sport Tail Lights stay on
    Hi everyone, I'm having a weird issue. As of about a week ago my tail lights won't turn off in one form or another. Either the full tail light or the side markers stay on 24/7. I normally leave the lights switch to auto but I've also tried leaving it in the off position without any difference...
  20. Vans28sk8
    2005 Ram 1500 Tail light mess
    I hope one of you guys can help me out. I purchased a 2005 1500 quad cab recently. The tail lights that are on there are older clear altezza’s that are fogged up and honestly just plain ugly. I ordered a new set of OEM replacements and went to put them in and to my surprise the left tail light...
  21. Drunken Hamster
    Intermittent bulb out light, right side brake light confirmed not working when it's on...
    Pretty simple, I've started getting lamp out warnings for my rear passenger brake light. The first time happened before I went and had the second muffler removed and a downturn put on, and I replaced the bulb [it WAS bad], but now it's happening again, and it's a little weird because the warning...
SeanD
