03 Ram 1500 2wd rear noise
Scott Willits
Middletown,Pa
4.7L
My pinion seal is toast and spitting oil all over, planning to replace that but I'm hearing a kind of whine noise when accelerating, however I have no play in my yoke other than backlash of 1/8" rotational. Curious of what the noise may be, I have been putting oil in case to keep lubricated till I can replace seal tonight. But any ideals of what could be making this noise? Could just replacing seal and putting clean oil in be the fix?
john p f
Oklahoma
Probably a pinion bearing going out. And causing the leak. Fix it quickly and you’ll save your ring and pinion set.
Scott Willits
Scott Willits
Middletown,Pa
4.7L
That's what I'm thinking, any reason I would hear it whining down during deceleration?
