1991 Dodge Rem 1500 odometer stopped working
hemimark
Plum
Ok fella's, my odometer has stopped working, speedo works. I replaced the gear set but that didn't help, still not working. Does anyone know of a company that can fix and bench test? Please let me know.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Did the Odometer just stop when it reached all 99999 S ?
Nice rides in your pix
u2slow
BC, Canada
Cummins 6BTA
Find another used one and try. It needs to be a 90-93 as these are electric.
I have several broken odo's now. Resetting the trip counter has broken at least one of mine. The speedos always keep working though.
H
hemimark
Plum
I will keep looking for a replacement but would love to find a place to repair it. Such a low milage truck and would like to keep it all original.
GTyankee
3.0 ecodiesel
I never messed with Chrysler speedos
If they are like OLD Ford & Chevy, you may have a hollow Flexible cable that goes from the transmission to the back of the speedo head.
Inside that flexible cable is a steel cable.
With this type of system, the inner cable is the weak link, it can snap in two.
The part that goes into the transmission has a square end
If i recall correctly, I may be completely wrong
the square end fits into an adaptor
the adaptor could be changed in the number of teeth it has, matches the diameter of the tire & the rear differential ratio ?
u2slow
BC, Canada
Cummins 6BTA
The 90-93 clusters are same and interchangable. I haven't found a place that repairs them. Since the speedo still works, I just got used to the odo not working.
@GTyankee the last year dodge used the mechanical cable drive speedo/odo is '89.
H
hemimark
Plum
Thanks Guys but Im surprised no one repairs them. Im on the hunt for a replacement now. If you sniff one out PM me!
d100experience
Center of USA
318 LA roller
I drove past this place a few months ago. Never knew they were there:
Their website says they do the electronics and mechanical repairs.
PaPitt
Stephenville TEXAS 76401
5.9L
There was a place in downtown Ft Worth Texas... I don't remember it's name but Someone mentioned them about 6 months ago . They said they'd had an old mechanical unit fixed.
... Google speedO repair in ft Worth . MAYBE IF THE OTHER PLACE DOESN'T PAN OUT . This one will.
