2) 10's or 1) 12
Discussion in 'Audio & Electronics' started by shawn1112, Dec 31, 2016.
  1. shawn1112
    shawn1112 Senior Member
    175
    43
    Aug 25, 2015
    Streamwood IL
    Ram Year:
    Engine:
    Getting ready to start a small audio build. Have never done an audio build in a pick up, so that's why I'm asking. Going to go with a Fox Box.
    Can't decide if I should go with 1) 12" sub or 2) 10" subs?
    Amp for sub will be between 500-750 Rms.
    Either going with a JL 750/1 or Apline 5 channel which will be 500 RMS to the sub channel.
    Listen to all types of music, mostly rap but will jam to some hard rock as well.
  2. Ferro
    Ferro Senior Member
    435
    192
    Sep 17, 2016
    Ram Year:
    Engine:
    2 10 would be much better than a 12". The 10s will move more air.
  3. Ram-engineer
    Ram-engineer Senior Member
    34
    197
    42
    Sep 17, 2016
    Ram Year:
    Engine:
    hemi 6.4
    For me I'd go 2 10's they got every beat not every 2nd like a 12 does and you can get some amazing sound out of them so they are a better daily used sub than a 12
    Sent from my Pixel XL using Tapatalk
  4. DILLIGAF
    DILLIGAF Senior Member
    713
    450
    May 28, 2016
    Canada
    Ram Year:
    Engine:
    2- 12'
  5. Etroze86
    Etroze86 Senior Member
    4,807
    834
    Nov 4, 2012
    Grand Forks ND
    Ram Year:
    Engine:
    Not sure what the second beat talk is as that just isn't accurate but what is true in the realm of subs and low power is cone area will be king. So you have a couple of choices. 2 10s will sound great depending on the subs but take up more room. One 12 can sound equally good again depending on the sub. Sticking with a foxbox I think you would be happier with 10s with low power and added cone area.
  6. djarrett
    djarrett Member
    71
    25
    May 30, 2014
    Monterey, TN
    Ram Year:
    Engine:
    What??
  7. shawn1112
    175
    43
    Aug 25, 2015
    Streamwood IL
    Ram Year:
    Engine:
    I didn't understand that either
  8. Kapt
    Kapt Senior Member
    480
    83
    Sep 23, 2015
    Ram Year:
    Engine:
    3L
    Went with 2 12's in mine. Love it!!
  9. tcazes
    tcazes Senior Member
    197
    48
    Dec 7, 2016
    Ram Year:
    Engine:
    5.7L
    hes saying the smaller 10s need less displacement therefore cycle faster which essentially produces more tones than a single 12. two 10s will always be cleaner, punchier, and still produce plenty of down low. id always go two 10s over a 12
    shawn1112 and Ram-engineer like this.
  10. shawn1112
    175
    43
    Aug 25, 2015
    Streamwood IL
    Ram Year:
    Engine:
    Now that makes sense.
    Did a lot of research yesterday and today and 99% sure I'm going with 2) 10's
    Leaning towards the Sundown Audio SD3's
Share This Page
