No, that readout is in MPG. It will range from 0 sitting idling, to 7 or 8 accelerating all the way up to 99 coasting downhill. It is the instant readout. Running on flat ground on cruise at 70 MPH it usually reads about 21 or so. The 19.9 MPG is the average since the last fill when I zeroed the trip A screen.Below is the hand calculated numbers since I got the truck new, based on full tank fills over 2 years.Dean, I'm assuming yours (27) is KmPG? Otherwise I'm failing something fierce.
Just curious, I am running the 8 speed transmission, what are you running that is different than that? Wider and heavier tires can definitely reduce gas mileage, so that would be a factor.Interesting. But I think I figured out the difference. You're riding on smaller tires and different transmission. I'm on 20" rims and Nitto tires.
