KyleCross1468
I have a 2001 Dodge Ram 1500 with the 5.2L it seems to change gears fine except it doesnt like to go up higher rpms even if pushed ab 1/2 3/4 throttle in the higher gears. The speedometer is off and it has a ABS light and Brake light on on the dash. I have replaced the wheel speed sensor on the rear diff and I made sure tranny was full. Also when cruising about 50-55 and you go to step on it to pass someone or getting up a hill it doesn’t seem to want to downshift and it’s almost as if the truck has no throttle response or it just likes to stay in overdrive and lug it’s way until it levels out then goes back to speed It revs fine in neutral it shifts through all gears but seems to lack in power when calling for it at higher speeds. Was thinking maybe TPS sensor or output shaft sensor but I’m at a loss there’s no Check Engine Lights on either. If anyone has any helpful information hit would be greatly appreciated.
