I strongly suggest you exercise due diligence, and familiarize yourself with a Chrysler factory Service Manual, rear axle section. If you are educated in the basics, you will be less likely to be ripped off. Any year fsm will probably work well enough, anything after 1978 will do, though generally the closer to your year, the better. I believe there is at least one service manual (2001, I think) downloadable on this site. If as someone mentioned, yours is a 9.25" ring gear axle, they haven't changed much except for abs. Since you don't want to fix it yourself, you only have two choices. You can take it to somebody like Randy's Ring & Pinion and be at their mercy. Or you can go to a reputable auto/truck junkyard and get a replacement axle with maybe a 90 day warranty. Don't know what that would cost, maybe $500. Better call around to find the going rate. You still have to pay someone to install it for you. The R & R labor should be just a couple-three hours if they have a lift and power tools, so no more than $250. You can pick your poison.
