dwoske
i recentlty replaced the engine in my ram 1500,a poorly installed lower radiator hose blew off.the engine was running fine after initial start up and leak check.i was driving and didnt notice the overheat condition. the engine subsequently stalled at low rpm and wouldnt restart.the next morning,while i was still unaware of O/H condition, i attempted to start engine started but extremely rough and sounded like a rod bearing failure.i removed sump and checked all rod bearings with no defects found .i then found lower rad hose disconnected. Ive now pulled intaketo check intake valves and seats, i will also pull valve covers do valve train insp as the engine is stiff to turn thru and also feels like there may be an obstruction. any and all ideas and experience would be greatly appreciated
