Hard to do 13's with that engine (without nitrous or FI, anyway). The gears (4.56's) and converter are the best starts for this. You didn't say if 2wd or 4wd. ****** thing about changing gears is it gets expensive with 4wd. You're starting with 310 at the crank, which will put you at about 250 or so at the wheels by the time it gets through that RFE. You need to get closer to 400 at the crank to get close to your target 1/4 time. Unfortunately outside of airram.com, not a whole lot of support for the 4.7, though I'm not sure anyone really has anything for the 08+ version. I think Superchips makes a programmer for yours; would definitely be worth looking into if only for the available trans tuning. Not sure if the 08+ 4.7 is custom tunable, if it is you can get custom tuning to optimize your combo.
