paintballer51
Hey ya'll, need help.
2010 Ram 5.7, had a collapsed lifter in #7 (P0307). Two years ago I had to put new cam/lifters in her. Ran great since then, until I got the #7 misfire. The lifter was barely squishy and I caught it in time where did not damage the cam lobe.
Ordered the same lifters (non MDS) and got it all back together, programed it with the predator that came with the cam/lifter job and tried to start it. Cranked but no fire, unless I mashed the pedal down but won't stay running.
Had the head machined
New head bolts
New (16) spark plugs
New head and intake gaskets of course
Still doing the same thing, my fuel pump turns on. Didn't check the fuel presure but feel like its fine. Tested the coil packs, took off and cleaned the Throttle Body. Map sensor looks fine. Still the same Random misfire/Mutiple miss fire (P0300)
Any thoughts on what is going on here. Thanks
New head bolts
