2012 - New Steering Wheel w/ radio controls - how to make work?
TwitchySumo
Ohio
I have a 2012 Ram Express with the standard RES radio (with Sirus XM.) I replaced the OEM steering wheel with a leather steering wheel w/ radio controls out of another 2012 Big Horn. The radio controls do not work. I have read that it typically works (plug-and-play.) Anyone know if I misread something or am I missing a step? Thanks!
jawzs2
South Jersey
If I remember correctly, on my son's 2012, I also had to enable them with AlfaOBD. Pretty sure the setting was "Remote Steering Wheel Switches".
T
TwitchySumo
Ohio
I have looked into the AlphaOBD threads and for some reason I keep interpreting them as: AlphaOBD can only be used on 2013+ model years. Did your son's 2012 also have the standard radio? (non-touch screen)
jawzs2
South Jersey
Actually, that was a mistake\misunderstanding when the was first posted. The software was initially written around 2005 or 2006 for the european market. and someone figured out that FCA uses the same modules throughout its vehicle line. It works fine on older models, just the features of what was available for the years are different. I've used it on my 2006 Charger R/T when I still had it, and have done a ton of stuff on my 2010 1500 with it.
His truck came with the non touch screen, no wheel buttons, and no uconnect. We put in an OEM nav(RHB), added the ucconnect module and steering wheel controls all at the same time.
metalchewy
Las Vegas
2010 TRX4
4.7L
The Alfaobd thread for our 2009-2012 4th gens is in the 3rd generation section.
T
TwitchySumo
Ohio
I see, thanks for clarifying.
Do you know if the non-touch screen radio can be controlled by the steering wheel controls (with my newly added wheel?) I will get educated on the AlphaOBD tool and purchase one if I can get it to work with my current non-touch screen radio and new steering wheel. I don't think I will need to run any new wiring, does that sound correct?
Here is a photo of my current radio just to be sure.
T
TwitchySumo
Ohio
Thank you VERY much for sending me to this. I will be reading up on this!
jawzs2
South Jersey
I can't see why not, my 2010 came with that radio and the steering wheel controls from the factory, I had the same radio, although my RES had the phone button for uconnect and it worked fine.
T
TwitchySumo
Ohio
Great to know. Thank you. I'll likely be getting an AlphaOBD now and giving it a shot. I will update this thread if it worked or not. It will likely be within a couple weeks. God bless.
