understood. I thought that much but wasn't sure. Honestly it is the first time I see this; tho, like anyone that has worked on cars/trucks I had multiple times the though ... "I should've bought the entire thing rather than put so much time and effort in patching it" Nevertheless, Thank you!!Easier & cheaper to replace the whole arm which is why you can't find just the bushings.
Labor on bushing replacement would exceed cost of a new arm.
#######Here's a pair for less than one factory arm:
https://www.partsgeek.com/gbproducts/AC/97149-07413295.html?utm_source=google&utm_medium=ff&utm_content=OAY&utm_campaign=PartsGeek+Google+Base&utm_term=2011-2014+Ram+1500+Control+Arm+and+Ball+Joint+Kit+TRQ+11-14+Ram+Control+Arm+and+Ball+Joint+Kit+2012&utm_source=google&utm_medium=ff&utm_campaign=PartsGeek+Google+Basecid=8846069446&aid=87978858646&keyword=332215776890:la-332215776890&kid=332215776890&gclid=EAIaIQobChMIzv2nhsC36wIVEiwYCh0NkwR4EAQYDiABEgJDEPD_BwE
I replaced my lowers with Moog a while back.
Factory arms are cast aluminum, Moog are solid iron with greasable ball joints.
####Yeah I see that now.
Seems the 2wd arms are more expensive than 4wd.
I'd avoid CARid for ordering anything unless you enjoy fighting for a refund.
####I've had good luck with Amazon for almost everything I've done to my truck. Brakes, suspension, exhaust, lighting, etc.
I read reviews, compare prices/vendors, and always get exactly what I want.
