2014 2500 hemi 3.73 vs 2014 2500 4.10
hounddog
Charlevoix, MI
2017 laramie 2500 credit cab 4x4 cummins
the 2014 2500 use the same frame as 3500 but you are right about most everything else..you can get a beefier rear end on a 3/4 ton too im pretty sure..the only difference on the motor is lower rpm capability and a flatter torque curve on the 1 ton
Sent from my SCH-I510 using Tapatalk 2
He compared a '12 2500 to a '14 3500.
They do not have the same frame.
He also said the '12 had a 5.7 vs the '14 having a 6.4. Apples and oranges.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
You won't save by getting smaller gears. You will burn up any savings lugging the load when you use it to tow and also be unhappy with it in comparison. No one ever says I want less power and ability. You will appreciate the bigger gears when you have them and miss them when you don't and you load it up. My opinion is based on my own experience and I can't speak for others.
$miley
regularcab2500
Buffalo
5.9 Magnum
yeah but you said 1 tons and 3/4 tons have different frames which for 2014 is not true..thats all any other year you are correct :)
hounddog
Charlevoix, MI
I'm well aware of what I said. I was responding to a specific post which said his '12 2500 and his '14 3500 are pretty much the same truck. They couldn't be more different.
As for the '14 differences, I've have two '14s, a 2500 and a 3500 dually so I know where they're the same and different. :)
Bigdaddy
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
Towing this wasn't too bad but I knew it was back their but this is about three yards of gravel along with the trailer which is about 2500 to 3000 lbs.
Loading up the gavel at my church not bad it was better than my 2011 ram I had.
Bigdaddy
Bigdaddy
6.7L Diesel Cummins
A couple more.
This was no problem I hardly couldn't tell it was their.
Bigdaddy
Bigdaddy
6.7L Diesel Cummins
Yeah I thought about it but I didn't want to wait for it, I'm happy with what I have those. I was so close to retirement and when I went to buy it and finance it I wanted to bank see that I was working.
regularcab2500
Buffalo
5.9 Magnum
i dont regret it but i do wish i got 4.10s. but around tax return time i wanna put 4.56s and a tuner on it anyway so im glad i didnt wait to order because i want something out of the ordinary
hounddog
Charlevoix, MI
You must really hate gasoline! Lol. I kid.
What do expect the fuel economy to be?
regularcab2500
Buffalo
5.9 Magnum
hmm i do mostly city driving so bad haha.. i just love the way high gear ratios make the truck jump
Bigdaddy
Bigdaddy
6.7L Diesel Cummins
So who are you going to get to install the 4.56s gears and is their a tuner out for ours truck?
loveracing1988
Clarkston, MI
Diablosport has had a tuner out for a while for the 2500 with the 6.4. Hemi fever actually has a tune for it too. Bullydog is supposed to be releasing a tuner for it as well, that one can adjust tire pressure thresholds which the Diablo tuner cannot.
Bigdaddy
Bigdaddy
6.7L Diesel Cummins
Which one is the best?
loveracing1988
Clarkston, MI
I don't know, I know the positives of the Diablosport tuners is the ability to run custom tunes like hemi fever. But since they won't adjust the tire pressure thresholds I will be going with bullydog.
Bigdaddy
Bigdaddy
6.7L Diesel Cummins
Cool I think I will just hold out for now.
