David_Jacobs
Hi all,
first post here but have been perusing the board for a while, great info here.
I thought the first post would be some feedback on the cam I installed this month. Cam install was MMX NSR for the RAM (incl. lifters and Kooks LT headers) and took me 5 days in a small dingy garage to install.
My main reason for the install was to avoid/reduce the risk or dreaded lifter failure and broken exhaust bolts, but I was also hoping for a small performance improvement at the same time.
I bought and installed a WB sensor, then worked with Sean at HF to fine tune the tune.
So my general, seat of my pants thoughts are that the idle sound great, very mild, offbeat. There were no meaningful performance gains from the stock HF tune I had (that I could tell from acceleration logs, before and after the cam/LT headers) but I suspect that the issue is that I still have the stock shift points and converter, so can't exploit any gains I suspect are there after 6k rpm. The engine does however feel "free'er"
I tuned with Diablo i3, so I'm looking at options to try change shift points to hopefully take advantage of the more open top end the cam hopefully gives me.
Anyways, anyone want more detailed info or feedback on the combination, I'd be happy to help.
PS Great service from Sean and MXX, will definitely use them again
Cheers,
Cheers,
