2014 ram 5.7 spark plug replacement
daveray9
I'm almost done with mine! I got 12 of them changed last Thursday, and saved the back four on the driver's side for this weekend when it's cooler and I have enough time to change them out. The passenger side wasn't all that bad, but the driver's side about drove me mad lol.
If you have a swivel spark plug removal tool the driver side is actually easier..
16RamHemi
Western Maine
Hemi 5.7 Sport Crew
this is a life saver! wohld not want to replace plugs again without it.
R.L.K.
Bristol , Tn.
My 13 had the 100,000 insert in the owners manual, but when I pulled the plugs last night they were COPPER LZFR5C plugs. 112xxx miles on the truck and the plugs looked pretty good still.
I thought they would have been the irridium plugs, so that's what I bought. I went ahead and put the irridiums in and will report back if any issues arise.
Any issues to report ?
Kong
Thale51
TN
Finished up the back four plugs on the driver side this morning! I just laid a blanket over the engine compart and laid straight over top of the engine to get to the plugs. Wasn't too bad, but I'm glad it's done now!
daveray9
Anyone switch to iridium but leave the same coil packs?
R.L.K.
Bristol , Tn.
Reading my mind Sir [emoji106]
I don't think this would be a good idea , but I do want to know if anyone has do e this with good results ??
misfit77
looking to buy one of the tools posted above...but one is 9/16 and one is 5/8...can anyone confirm the correct size?
misfit77
Well according to NGK site, the OEM laser Iridium SP143877AB NGK PN#LZFR5CI-11 Stock #92145 is 5/8"
Product Attributes
Center Electrode Core Material: Copper Core
Center Electrode Tip Material: Iridium
Ground Configuration: Standard
Ground Electrode Core Material: Nickel Core
Ground Electrode Quantity: 1
Ground Electrode Tip Design: Standard
Hex Size: 5/8 in
Insulator Height: 50.50 mm
Manufacturer Heat Range: 5
Pre-Gap Size: .044 in
Reach: 26.5 mm
Resistance: 5000 Ohms
Seat Type: Flat
Thread Diameter: 14.00 mm
You've got it figured out right,lol.You want the 5/8" version.That socket makes doing the plugs almost livable,lol
RVGuy
Alberta, Canada
Old thread, but I changed out my plugs for Champions when I did mine. They were on sale, I got all 16 iridium plugs for $86.
Been in the truck for 100,000km without issue so I don't see why everyone says you have to use NGK.
misfit77
4 hours, some Coke Zeros and a few scratches later I got'r done.
Thanks for the tool recommendation Roadrnnr. That Gearwrench worked magic for the Ram.
In the past I got away with my Craftsman sockets, but it has always been inline 4, and V6s.
A thing I noticed... The dealer part and NGK sites said my truck has SP143877AB (NGk Laser Iridiums LZFR5CI-11) but I pulled out LZFR5E-11.
Maybe my truck was an early run.
Oh well I was able to score the Laser Iridiums for the same price that one of our vendors is selling standard plugs.
