chamolie
- Jun 18, 2017
- 73
- 37
- 2016 SLT
- Cummins 6.7
I have a 2016 2500 6.7 SLT
Factory came with uConnect 5.0 RA2 and 4 speed manual blower fan.
in february 2016, I installed a uConnect 8.4 RA4 from infotainment and also purchased a 4 speed to 7 speed conversion harness from the harness connection and all went well, not an issue.
in fall 2017 I added ATC with OBD Genie, used a dual zone bezel instead of single as the price was good and all was working perfectly fofr a couple of months.
While working out of town in November 2017, I went to a different dealer at the town we worked in for an oil change.
They called me later and said that there was a software update for my truck so I said sure, go ahead and install.
when I picked up the vehicle, they said that it took alot longer to update because they were having problems with a module.
A couple of days later, when I switched the HVAC to AUTO and heat was coming out of the vents to your face, instead of the defrost.
Now, whenever the truck is started after sitting for a few minutes, the rear defrost light flashes for a minute while the fan turns onto high speed and the actuators cycle as if trying to calibrate.
Went to my local dealer where i purchased the truck, go to for all maintenance and repairs, when they scanned the HVAC system, the error is with the blend door.
Well, there is no blend door on the single zone HVAC system and the dealer is unable to help me at this point because of the modifications.
I checked all connections for the 4 spd to 7 spd conversion and everything checks out.
is it possible that the other dealer flashed or updated the HVAC module?
I verified the module is still the original 4 speed module part (68105017AE)
Now my second issue is with the heated/cooled seats and wheel installed this week.
I purchased Limited Seats, limited console, heated steering wheel and instrument switch.
after installation, the front seats heat up with the switch and 8.4 RA4 after the OBD Genie install.
The cooled seats and heated wheel still DO NOT work even after the OBD Genie activation.
All controls show up on uConnect , when i press the cooled seats and heated wheel, the button is highlighted for 5 seconds, no click sound from module and the instrument panel button does not illuminate, then the button on the uConnect shuts off after 5 seconds.
The rear heated seats DO NOT work at all either.
I have also purchased an autoenginiuty scan tools with advanced Chrysler group which i will pick up in the next couple of days.
wiring under drivers seat:
wiring to console with heated seat switches:
very nice interior with Limited Door Panels
Under Passenger Seat:
Connections at Rear Seats:
