My Cruise Control works fine with a trouble code.When you have a Trouble Code, the Cruise Control will not function
Wonder if that was issue? This came out of nowhere a little bit after my gf told me she filled it up and pushed more in after the pump stopped. Told her no more of that. I also tried looking with alfaodb and I have a check engine light along with a gas cap light. No clue why this evap code isn’t showing up with alpha odbI replaced every component in the system, and I still got the code. I finally performed a smoke test on my truck this spring, and there is a small leak coming from the top of the fuel tank. I need to drop it one of these days to fix it.
Thats called the evap canister vent filter located on the side of the filler neck, caused sometimes by overfilling the gas tank, shut off after first click.I replaced every component in the system, and I still got the code. I finally performed a smoke test on my truck this spring, and there is a small leak coming from the top of the fuel tank. I need to drop it one of these days to fix it.
