2019 RAM 1500 LARAMIE SPORT SEAT BELT CHIME DISABLE
RevRonnie
Hey Everyone,
Does anyone know how to disable the seat belt chime on a 2019 Ram yet? I tried the buckle unbuckle 3Xs and it isnt working. I know I'm sure to get the obligatory " Just buckle it" posts. I do wear my seat belt on the street however I also do a lot of driving at my camp very slow speeds on dirt roads and frequently getting in and out of the truck. The seat belt chime is driving me nuts!!! Help is appreciated
Dominacb
New jersey
Hey Everyone,
Owners manual have it? My 16' let me go the seat belt trick
Bret
Webster, TX
Hey Everyone,
Did you figure it out? I googled and couldn’t find anything.
RevRonnie
RevRonnie
No I haven't found anything either
On my 2001, the switch was messed up so, even if I had my belt on it would think that I didn’t and alert me. I unplugged the harness under the seat and made a jumper with spade connectors and plug that in and it did the trick.
adrianp89
Tampa Bay, FL
Spent two hours reading the entire manual.... didn't see it. Of course I might have missed but I don't think so.
Kfield
Johnson City
I have turned mine off following the procedure of the 3 buckle and in buckle method
Just like my 17 at low speed, under 5mph I believe, you still get the message in the cluster but no chime.
Jus Cruisin
Gearhead
Metro Detroit area after 28 years in Florida
2019 Limited 4X4
E-torque hemi
The 3X works. There are a few YouTube videos out. You must engage the seat belt before you put the truck into the run position then do the 3 and shut it off. You'll get the ding when you do if you did correctly.
Rayzram
Yep the 3 buckle method worked perfect for me
19Streak
Ontario
Fellas. I've tried the 3x method and I get the usual "ding" to let me know it's worked. But I still get the seat belt chime. Does that 3x method only work under a certain speed?
Kfield
Johnson City
I did it like 3-4 times till it actually disabled. Even though got the completion ding each time.
19Streak
Ontario
I guess I will go back out and try again! I'm having a heck of a time getting my homelink garage door opener to work as well. Haven't had any issues with my last 5 rams but can't seem to get this one working
Kfield
Johnson City
I am having issues with my garage door, but my parents garage programmed first try.
Kfield
Johnson City
Anyone have a write up for it? I can't view videos.
Get in truck
Fasten seatbelt
Turn truck on
Wait till seatbelt light goes off
Fasten and unfasten seatbelt 3 times quickly
After third unfasten refasten seat belt
Turn truck off with seatbelt fastened, done correctly there will be a chime
If no chime repeat steps again.
Note: Done correctly the fasten seatbelt light will stay illuminated but won’t blink or chime. At low speeds, starting and stopping the fasten seat belt message will also appear in Evic. It may also take multiple successful attempts to finally disable chime.
19Streak
Ontario
On my fifth attempt the seat belt chime is turned off. Little odd that it took 5 attempts
Martinc7395
