Seat belt warning chime
Mayab
Pennsylvania
Hello all
Does anyone know the procedure to deactivate the seat belt chime for the 2024 6th generation ram. The sequense for the 2023 does not work
Thanks in advance
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
try buying a MINI 3" rigid seat belt extender
just insert it into the right side of the seat
that should shut off the chime
the 3" also comes in handy when the weather is Cold & you need a heavy jacket or coat
GTyankee
3.0 ecodiesel
I bought both a 3" rigid, called the MINI
a 5" rigid, which i don't think i will ever use
I did not know which size would be best for my large belly
their site reads that it covers the 2024 models
brian42
San Diego, CA
For your 5th gen RAM:
1. Get in the truck and shut the door.
2. Buckle your seat belt.
3. Turn the truck to ON (do not start).
4. Unbuckle your seatbelt and rebuckle it 3 times (leaving it buckled on the 3rd time).
5. Turn the truck OFF (you should hear a chime).
6. Unbuckle your seat belt.
You will still have the warning light in the instrument cluster but no more reminder chime.
