3.30pm Saturday Recovery what could go wrong !
olyelr
Kewadin MI
Argh, see no cv's turning, gotta be in the case, LOL.
In the case? If the tires are spinning but the shafts arnt, dosnt that mean there is an issue at the hub? The shafts should spin with the tire, there is no disconnect out there.
turkeybird56
Central Texas
Honestly, I do not know enuf on that stuff to say, gotta leave that to the experts. The right front shaft that was all twisted that Dilligaf pulled, wow, lots of torque applied. Where the actual problem(s) are, well I think Dilligaf knows enough on what he is doing and hopefully he will report back on all his findings. I have only helped to pull CV's on a Humvee, and that is a lil different. It was either help or my Humvee sit and dead-lined forever, LOL.
ADDED: Seeing that damage makes me wish I still had my '74 Cherokee. That monster go ne where and pull ne thing out. But talking an apples to oranges comparison.
danielmid
Southeast WI
2015 Sport 4x4
I think that's the axles this YT channel put on his sponsored Ram, then broke the inner pass shaft a bit later:
DILLIGAF
DILLIGAF
Canada
Yeah just saw that as well.
I think Ive come to terms that my truck goes thru 1 set of Cardone HDs a year.
Might fab up limiting straps at this point.
danielmid
Southeast WI
2015 Sport 4x4
I'm sure there's a power wagon axle somewhere in CA just waiting for you.
ram1500rsm
Trabuco Canyon, CA
Mm I'll insist on the stock cv axels as the only way to go. **** made in China parts in there. The aftermarket doesn't seem to know to make cv axels that last. At least the cheapy aftermarket that makes oe stuff. I don't hear anybody messing up with the Dirt King cvs , granted those won't fit with stock length lower arms :)
My OE tierods, front lowers and cv axels are still unmolested after 123k miles and my truck sees rocks, dirt sand and some snow mostly cause I hate mud and don't care much offroading around it. Sure this parts are more expensive from the dealer but darn they last. I'm very inclined to get those from the RAM dealer online or local whoever gives me best price when the time comes.
DILLIGAF
DILLIGAF
Canada
OEM axles dont last any longer compared to Cardone HDs in my truck. Even if they lasted 2x as long its still cheaper to go with Cardone HDs...lol.
Just pulled some measurements. 18" limiting straps seems to be what I need. Had this same issue on my SxS and the limit strap stopped my axles from breaking.
His abilities as a Ram mechanic suck.You don't need the outer axle shaft bolted back into the wheel/unit bearing to hold the wheel on,if that was the case the wheels would of fell off my truck years ago.My 4X4 that hasn't had any of the 4X4 pieces ahead of the transfer case installed for 8 years. Somebody should tell him the wheel bearing hubs are identical between a 2X4 and a 4X4
turkeybird56
Central Texas
olyelr
Kewadin MI
Yea, when the suspension is drooped out with a tire hanging and spinning with no traction, and then it comes back into contact with terrafirma and gains traction when still mostly drooped out and spinning…BANG
DILLIGAF
DILLIGAF
Canada
Ordered some goodies, Will even be able to use the front sway bar hole on the LCA :p
8" Limiting Straps
Clevis weld bock
Limit strap Clevis
Shear Tab
Will start a DIY thread once I get started :birgits_tiredcoffee
This is what im planing to do.
nc_ohc=-7pGXcp5WZIAX_z1J-h&_nc_ht=scontent.fyxd1-1.pngfs-4runner-test-droop-bilstein-clevis-mount-krylon.jpg
DILLIGAF
DILLIGAF
Canada
Finally got the NOCO charger to stop blinking red. ( Will flash green at 75% charge ) Took 2 days on the trickle charger to get it back up.
Hopefully I get a full green light tomorrow. and ill test the CCA again
Marshall
Sk, Canada
2014 sport
Well then the canooks need to google it lol
Does google work up there? lmao
Hell no, I just ask the youngest granddaughter, she know everything, other than where she tossed her stuff.
Joey93
