35x12.5 tires
BrandonD29
Medicine hat
Just wondering how much of a lift/level is required to fit 35x12.5 R18s on an 05 ram 1500 4x4 without rubbing
Aftermarket rims, think they have a 1 inch offset, but im not positive.
CincyZach
Cincinnati
ram-1500-trucks-lift-kits-overview.html
Looking at this website real quick it looks like you will need a 3"-4" lift. Usually when you research a lift and look at the details of the lift, it will tell you what the max tire size is and on what size and offset rim it will need to be on.
Logan Klein
Arkansas
4.7 Magnum
3 inch lift or higher will fit 35 inch tires. you may have to trim away some of the plastic in the wheel wells to solve any rubbing in that area. You may also experience problems with the truck chewing up front end parts, but that's across the board when installing big tires.
acolic
Hamilton
Hi,
I have been looking at a 4" lift and per the manufacture web site that will fit
35x12.50 R20 35" instead of my existing 275 60 20 33" tires.
I am not sure 2" in tire size change in height and 1.5" in width is much better?
Can someone comment if it's worth it?
Thanks
Alex
shawnm105
missouri
I have a 05 1500 2wd with a 3” leavel kit on front i just put 35 12.5 20 on factory wheels no rubbing at all
