3rd Gen Technical Service Bulletins
Status
Not open for further replies.
L
lilfroger
5.9 CTD
TSB 0300107: 4WD System May Not Engage
Service bulletin #: 0300107
replacement sb#:
Nhtsa item #: 10022418
date: 20070721
failing component: 105500 power train: Driveline: Differential unit
make: Dodge
model: Ram 1500
year: 2006, 2007
date created: 20070813
description of summary: 4wd system may not engage or disengage as desired with (serv 4wd) message illuminated. *kb
L
lilfroger
5.9 CTD
TSB 2304106: Lens Fogging
Service bulletin #: 2304106
replacement sb#: 2303507
nhtsa item #: 10023351
date: 20070808
failing component: 120000 exterior lighting
make: Dodge
model: Ram
year: 2006, 2007, 2008
date created: 20071204
description of summary: Exterior lamp - lens fogging. *nj
L
lilfroger
5.9 CTD
TSB 1100307: Diesel Emissions Testing
Service bulletin #: 1100307
replacement sb#: 11-002-08
nhtsa item #: 10023396
date: 20080521
failing component: 063100 engine and engine cooling:exhaust system:emission control
make: Dodge
model: Ram 2500, 3500
year: 2007, 2008
date created: 20071206
description of summary: Cummins 6.7l diesel turocharger - necessary system inspections and tests. *nj updated 6/17/08. *nj
L
lilfroger
5.9 CTD
Tsb 1804407: Dtc p0524
SERVICE BULLETIN #: 1804407
REPLACEMENT SB#:
NHTSA ITEM #: 10023422
DATE: 20071012
FAILING COMPONENT: 061000 ENGINE AND ENGINE COOLING:ENGINE
MAKE: DODGE
MODEL: RAM
YEAR: 2008
DATE CREATED: 20071210
DESCRIPTION OF SUMMARY: MIL ILLUMINATION DUE TO DIAGNOSTIC TROUBLE CODE (DTC) P0524 - ENGINE OIL PRESSURE TOO LOW. *KB
NOTE., This bulletin applies to the above listed vehicles equipped with a 5.7L engine
with MDS (sales code EZB) built before the following dates:
* (HB/HG) built before August l5, 2007 (MDH0814XX)
* (LX) built before September 14, 2007 (MDH 0914XX)
* (DR) built before August 16, 2007 (MDH 0816XX)
* (WK/XK) built before August 23, 2007 (MDH 0823XX)
L
lilfroger
5.9 CTD
TSB 2101907: Harsh 2nd / 3rd Shift
Service bulletin #: 2101907
replacement sb#:
Nhtsa item #: 10023587
date: 20071114
failing component: 103100 power train:automatic transmission:control module (tcm, pcm)
make: Dodge
year: 2007, 2008
date created: 20080110
description of summary: Flash: 68rfe transmission - harsh coastdown shift and/or harsh 2-3 upshift. *nj
L
lilfroger
5.9 CTD
TSB 7048: Steering Dampner Bolt
Service bulletin #: 7048
replacement sb#:
Nhtsa item #: 10023639
date: 20071115
failing component: 010000 steering
make: Dodge
model: Ram
year: 2008
date created: 20080118
description of summary: Steering damper bolt that may not have been tightened to specification. *nj
L
lilfroger
5.9 CTD
TSB 2100608: Shift Shudder
Service bulletin #: 2100608
replacement sb#:
Nhtsa item #: 10024062
date: 20080115
make: Dodge
model: Ram 1500
year: 2007
date created: 20080304
description of summary: Flash: Torque converter shudder with coordinated change or 1-2 or 2-3 shift harshness. *nj
L
lilfroger
5.9 CTD
TSB 2500108: PCV Vent Freezing
Service bulletin #: 2500108
replacement sb#:
Nhtsa item #: 10024083
date: 20080108
failing component: 063110 engine and engine cooling:exhaust system:emission control:crankcase (pcv)
make: Dodge
model: Ram
year: 2003, 2004, 2005, 2006
date created: 20080306
description of summary: Positive crankcase ventilation (pcv) system freezes in extreme cold ambient temperatures -- involves installing revised pcv system components. *nj
L
lilfroger
5.9 CTD
Tsb 08-036: Injection pump fuel control actuator
Service bulletin #: 08-036
replacement sb#:
Nhtsa item #: 10024892
date: 20080423
failing component: 073000 fuel system, gasoline:fuel injection system
make: Dodge
model: Ram
year: 2008
date created: 20080605
description of summary: 2008 (dh/d1/dc/dm) - injection pump fuel control actuator. *nj
L
lilfroger
5.9 CTD
Tsb 08-007-08: Electronic lockup of the wcm/skreem
Service bulletin #: 08-007-08
replacement sb#:
Nhtsa item #: 10024966
date: 20080304
failing component: 061000 engine and engine cooling:engine
make: Dodge
model: Ram
date created: 20080611
description of summary: No engine crank or no engine start due to electronic lockup of the wcm/skreem. *nj
L
lilfroger
5.9 CTD
TSB 11-001-08: Turbo Charger Cleaning Procedure
Service bulletin #: 11-001-08
replacement sb#:
Nhtsa item #: 10025162
date: 20080521
make: Dodge
year: 2007, 2008
date created: 20080715
description of summary: Turbocharger cleaning procedure due to excessive soot accumulation for 2007-2008 (dh/d1) ram truck (2500/3500). *pe
L
lilfroger
5.9 CTD
TSB 08-004: Steering Shudder during low speed
Service bulletin #: 08-004
replacement sb#:
Nhtsa item #: 10025346
date: 20080630
failing component: 015200 steering:hydraulic power assist:hose, piping, and connections
make: Dodge
model: Ram 1500
year: 2003, 2004, 2005, 2006, 2007, 2008
date created: 20080730
description of summary: 2003-2008 (dr) ram truck 1500-steering shudder during parking lot or low vehicle speed maneuvers. *pe
L
lilfroger
5.9 CTD
Tsb 21-018-08: Ctd p0740 or p1798
Service bulletin #: 21-018-08
replacement sb#:
Nhtsa item #: 10026168
date: 20080712
failing component: 103000 power train:automatic transmission
make: Dodge
model: Ram
year: 2008
date created: 20081003
description of summary: Chrysler/dodge/jeep: Flash: Diagnostic trouble code, dtc p0740 or p1798 and automatic transmission shift improvements 1-2 or 2-3 cold shift improvements. *pe
L
lilfroger
5.9 CTD
Rrt-08-097: Not allow low gear selection
Service bulletin #: Rrt-08-097
replacement sb#:
Nhtsa item #: 10028388
date: 20081217
make: Dodge
model: Ram
year: 2008
date created: 20090327
description of summary: Chrysler: Dodge: Approximately 2969 vehicles, equipped with an automatic transmission, may have been shipped with a gearshift cable that may slip out of adjustment and not allow low gear selection. *pe
L
lilfroger
5.9 CTD
TSB 08-011-09 : Turn Signal Swith Malfunction
Service bulletin #: 08-011-09
replacement sb#:
Nhtsa item #: 10030905
date: 20090708
failing component: 126200 exterior lighting:turn signal:switch
make: Dodge
model: Ram 3500
year: 2006
date created: 20091218
description of summary: Dodge/jeep/chrysler: Multifunction switch malfunction; extended warranty. A turn signal switch malfunction that will cause the turn signals to flash incorrectly. When right turn is selected, the left flashers will function and the same when the left turn is selected, the right flashers will function. *pe
L
lilfroger
5.9 CTD
Tsb 09-002-09: Repair procedures for dtc p2262
Service bulletin #: 09-002-09
replacement sb#:
Nhtsa item #: 10031004
date: 20090613
failing component: 061120 engine and engine cooling:engine: Diesel :turbo-charger
make: Dodge
model: Ram
year: 2007, 2008
date created: 20091230
description of summary: Dodge: Revised diagnostic and repair procedures for dtc p2262-turbocharger boost pressure not detected-mechanical. Recent pcm calibration updates have improved the robustness to this dtc through updated diagnostic strategies. *pe
L
lilfroger
5.9 CTD
Tsb 18-024-09: Stationary desoot
Service bulletin #: 18-024-09
replacement sb#:
Nhtsa item #: 10032004
date: 20090806
make: Dodge
year: 2007, 2008
date created: 20100203
description of summary: Dodge/chrysler: Mil illumination and stationary desoot and other enhancements. Involves selectively erasing and reprogramming the engine control module (ecm) with new software. *pe
L
lilfroger
5.9 CTD
Tsb 18-009-09reva: Driveability improvements
Service bulletin #: 18-009-09reva
replacement sb#:
Nhtsa item #: 10032788
date: 20091101
make: Dodge
model: Ram
year: 2007
date created: 20100524
description of summary: Jeep/chrysler/dodge: Flash; driveability improvements. This bulletin involves selectively erasing and reprogramming the powertrain control module (pcm) with new software. *pe
L
lilfroger
5.9 CTD
TSB J-35: Excessive Soot
Service bulletin #: J-35
replacement sb#:
Nhtsa item #: 10033113
date: 20100401
make: Dodge
year: 2007, 2008
date created: 20100708
description of summary: Dodge: Engine control module (ecm) software program on about 159,700 trucks may cause illumination of the malfunction indicator lamp (mil) when no problem exists or under certain conditions allow heavy sooting of the turbocharger, exhaust gas recirculation valve and diesel particulate filter. Heavy sooting could damage emissions components and result in increased emissions. The engine control module must be reprogrammed (flashed). Csc letter was rec'd. *pe
L
lilfroger
5.9 CTD
TSB 09-050: Fuel Tank Assembly
Service bulletin #: 09-050
replacement sb#:
Nhtsa item #: 10033185
date: 20090825
failing component: 071100 fuel system, gasoline:storage:tank assembly
make: Dodge
model: Ram
year: 2007, 2008
date created: 20100723
description of summary: Dodge: Improved fuel tank venting. Vehicles were shipped with a fuel tank vent that under severe conditions, may allow moisture and debris to enter the fuel tank through the vent. Dealers are requested to replace the fuel tank vent with a revised part. *pe
Status
