4th Gen Ram 3"/5" drop
Uaintlo
Running a 2/4 on 24's. Have given a little thought on cutting could but I've been hesitant because I don't know what that would do to my clearances and ride.
what size tires are those?
Uaintlo
I want to lower mine this weekend,
but its been so damn hot outside, and I don't have a garage..
Jonv8944s
So last Friday I bought a new 2016 Ram 1500 Reg Cab. 2WD. By Saturday I figured out it needs to be lowered.
I ordered the BellTech 2/4 kit, and the HellWig sway bar. All of it should be arriving by the end of the week so I can hopefully install it all.
I have a couple of questions:
1. How much of an issue am I causing if I dont get the adjustable upper and lower links? I know that whole pinion angle stuff is the big concern, but what if the car drives fine after I do the lowering, do I still need to get this done, as it will inevitable cause some issues?
2. I remember reading that with the BellTech SP kit, that I should keep the stock fronts and just replace the stock rears with the SP shocks. I cannot find that thread, and I am wondering if this is consensus, or do I need to just use all 4 of the supplied SP shocks and replace the full stock setup?
Fantastic thread btw, thanks so much for all those who have assisted.
Jon
Jonv8944s
Yup, I literally have read every new one of the 'lowered' threads I could find on this forum. I reread them many time too. I am just trying to remember which one said to leave the front shocks stock, but use the SP's in the rear when doing the lowering. If the concensus is to just use all 4 of the SP shocks in the belltech setup, then I will. The QA1's sound great, but I am already buying headers and trinity tune, belltech 964SP, Hellwig rear sway bar (mine came with no rear one, so I got one), and then some other dodge/ram stuff like bed liner rug, aluminum ramps (helps to get gokart cargo in there :happy107:) and a trailer hitch (to just tow a jet ski).
So I have to set a budget somewhere, and this is what I THINK I need to be happy with the truck. The only thing I am trying to do is maximize my setup and make sure I am putting the proper setup together for the shocks.
Anyone have any insight if that thing I read somewhere on here (cant find it anymore), is right about just using stock front shocks but using the SP rears?
Thanks,
Jon
moregrip
Thanks,
Jon
I'm getting ready to do my Belltech drop soon and I'm leaving both front and rear stock shocks on there for a little while. Like you, due to the cost of everything else I will have to do this in stages and plan to swap those out with more performance oriented parts in the future.
With the tires, drop springs, sway bars, rear control arms and panhard bar the cost adds up!:patriot:
Uaintlo
Cut the coils of my Belltech 2/4 kit last night, gunna install them tomorrow
razor1
St.Petersburg Fl
this is the point where the ride is going to suffer I think. At speed and small bumps ,mine is fine with the 2/4 drop. Big drips in the road, potholes etc, mine hits hard even with Airlift bags in the rear.
Jonv8944s
so even the 2/4 drop causes issues when you hit decent bumps? And yes, even though I would like to go lower, my belief is that anything more then the 2/4 is likely a huge trade off in ride quality vs looks, and honestly ride quality trumps looks at a certain point. Matter of fact, I am only really doing the drop so I can get better handling, as I am an aggressive driver, and this truck wobbles around too much when pushed hard.
Lastly, ANYONE want to confirm or deny if I should be using the full belltech SP shock setup, or if I am supposed to mix oem fronts with SP rears?
Thanks!
Jon
R/T_Fire
Pleasant Grove
Mine does this also, but wasn't bad or as bad before I put the spoon arms on.
To get the axle centered and such it puts a arch in my springs and the bumps don't align very well anymore. I'm thinking I'm going to pull the axle back forward until I get in and realign everything to have the right geometry to match the modified drop.
I know it works and many drive like this but to me its not 100% right and I can improve it to be right so I will when the bed comes off, gas tank is relocated for balance and I design and fab up a watts link for the rear. Its alot of work for a little gain but its my hobby and enjoy Fabwork and redesigning things to work. so its worth it to me
Thanks!
Jon
I too am a very aggressive driver with a estimated 3/5 drop. as I mentioned above all what mine did and how it road well prior to me adjusting the spohn arms. If your ok with the axle being forward in the wheel well then you should be fine. Me I'm not so thats why I list my over the top solution. but that fits me cause I plan to use this truck in Auto-X racing for sport. not planning on winning any trophies with it.
Uaintlo
installed my cut Belltech kit today
Jonv8944s
Anyone have their drive shaft Harmonic balancer (big circle right near differential Universal Joint), rub up against the gas tank heat shield?
mine does when driving aggressively in a turn. (Straight no issues).
Do they all have this very large vibration balancer on all years, or was this a 2016 thing?
Thanks,
Jon
razor1
St.Petersburg Fl
mine is a 16 also, I have it and really had to bend the crap out of the shield to get it to stop touch the ring.
DERJ
Austin
2014 R/T
When my 2014 R/T was dropped 5" out back, I had the same thing, too...
Jonv8944s
Phew, ok, at least I know I didnt do anything wrong ;). I was wondering why no one made mention of it in any of the threads I read on the subject.
I'll see what I can do to reduce the likelihood of rubbing.
Thanks!
Jon
Uaintlo
Put my wheels on tonight, 24" Intros
the back is too raked for my liking, so Im gunna have to cut more to get it to come down a bit more
4.7 v8
I started with the McGauheys 2/4 drop.....
For the HD conversion you'll need hood, grill, headlight fillers and bumper.... bumper brackets must be modified in order to fir the 1500 frame
Joey93
