Jmhm17
- Feb 17, 2014
- 1,402
- 495
- Location
- Massachusetts
- 2014
- 5.7L HEMI
Wait.. i thought ALL AWD vehicles had center diffs... and 4x4's had T-cases.. hence why no binding on dry roads.
No, the debate came in because it was said that AWD has a center differential, which very few vehicles have nowadays.
I never said you said it...I never said it had a center differential. I said, AWD is a different beast from 4WD. But I keep getting quoted and told about the technical workings of AWD. Which really doesn't matter for the point of.. 4wd and AWD are different in that AWD is typically designed to be always on (not selectable) and a typical 4wd is meant to be used in low traction situations. Yes, there are a variety of different variations of these systems that allow different things.. but holy crap, I just said that the typical two are freakin' different and one should only be used in low traction.
my bad i thought i read somewhere that 44-44 transfer case was used in 2010 and later guess not lol sorry for the miss info
I was just going by what the Ram engineer told me. According to him they started the use of that transfer case in 2013.You are close...Ram actually started using the BW 44-44 transfer case in 2011. Loveracing1988 and others are incorrect. A quick search on Google reveals that the issue has been prevalent in some 2011 and 2012 trucks. See attached files.
He may have, but I don't know why he would, the discussion / argument was strictly about the 44-44 and how great it is and how could I not love their premium transfer case.From my understanding, Ram switched to using the BW 44-45 part time transfer case in 2013 from the previous New Venture part time transfer case. That must have been what the engineer meant.
I to was wondering what the different 4wd modes are used for. a lot of good info here
For me it goes like this:
2WD - Everyday driving, ALWAYS use this on pavement unless I'm going perfectly straight and even then I tend to not need 4WD. I tend to stay in 2WD until I "need it," like going up an icy hill or the roads get bad and I want to stay straight.
4WD AUTO - When 2WD isn't enough but pavement patches arise, like sectional snowdrifts across the road (snow/pavement/snow/pavement etc.) Or stuck on ice but 20ft up is pavement.
4WD LOCK - If theres a foot of snow on the ground or I want to go through mud, or I'm backing a trailer on grass up hill in reverse and 2WD isn't cutting it. I typically try 2WD first, for no real reason, and use 4WD as a "last resort" for no real reason either.
4WD LOW - Now this is the TRUE last resort. I use this mode when I'm stuck in all other modes, or I'm off-road and want to go slow over rough terrain. I've also used this to drag heavy things with ease. This is also fun if you want to fling mud everywhere.
Thats just the way that I do it anyway, I'm sure others will have slightly different nuances. Most of the time I use 4WD just for fun.
Realistically the only time you will use 4 low is when you need extra torque. Rock crawling, pulling a stump out of the ground, pulling a car out of a ditch, those kinds of things.Lots of info here, but how about 2010 RAM Sport with 4WD Lock and 4WD Low options only.
My assumption is:
4WD Lock - Snow Covered Roadways, Deep Snow, Mud etc.
4WD Low - When you get stuck and above 4WD Lock is not cutting it.
Do I have it correct?
So using 4 Lock won't damage anything while driving on snow covered roads? Mine doesn't have the 4 Auto.
My configuration:
2wd
4wd low
4wd lock
neutral
you'll be fine in 4wd on slippery surfaces. But try to avoid turning hard, even semi hard, in 4wd when you have traction.
Part-time transfer cases, without an "Auto" feature, (what you have) have no way to differentiate the RPM of the front and rear driveshaft when they're engaged in 4wd, so they're forced to spin at the same rate - which puts extra stress on the entire drivetrain during turns.
