GP4L
This might be way off topic by now. Or even a repeat. But what pissed me off is when I'm in a pinch and go to 4 lock. Then only 2 wheels spin. Granted it happens in every 4wd. Just a major pet peeve.
give it some gas...
Thanks for the info, first 4wd truck and we are approaching winter really fast. Kind of itching to see how it performs in snow here. I'm hoping the factory 17 in Wranglers M/S will be good for our winters.
I read through the 13 pages and there are a few points that were left out.
1) trucks that have the center diff / auto 4 wheel option are inferior offroad to the trucks that lack the center diff. If you notice the trim levels the bighorn, sport, and Laramie are meant primarily for touring and pulling loads on the highway. This being the priority having a center diff is functional since it allows for the 4 wheel auto option.the HFE, tradesman, and outdoorsman, are clearly meant for offroad use since they don't have the center diff.
2) the 4 wheel lock option means you are locking the center diff not the rear axels. Don't think for a second 4 wheel lock is the same as 4 wheel hi. It's not. In 4 wheel hi the rear left tire and the front right tire spin at the same speed. This is why you should never put your truck in 4 wheel hi on dry pavement and turn. The rear tire is forced to spin slower than the front and that puts tremendous stress on the diff. 4 wheel lock simulates this by locking the center diff. Even though the center diff is locked, it will allow slippage which permits you to drive in 4 wheel lock on dry pavement. This slippage will also occur in less convenient times in situations offroad where you want the power through something. In 4x4hi no matter what both the front and rears will spin or you'll blow the diff or shred your tires trying. In 4 wheel lock you will stop spinning the wheel that's jammed and only spin the opposite wheel that isnt.
3) if you don't believe that center diff 4x4 systems are inferior ask yourself why the rubicon, powerwagon, and hummer h1's don't come with a center diff.
You are right about the fact the 44-44 is inferior off road you are incorrect as to why. There is no center differential in any of these trucks, the 4 auto case uses a clutch to engage and disengage power to the front axle.I read through the 13 pages and there are a few points that were left out.
You'll be fine. The Wranglers aren't that great, but my first major snowfall experience was a good one (two weekends ago in Chicago). Zero issues that won't be bettered by anything besides better tires. Oh, and i have the "inferior" transfer case
Also 4 lock is the same as 4 hi for every other manufacturer provided you are referring to 4 lock in the 44-45 transfer case.
Fair enough, whether a center different or clutch mechanism, it's inferior. My general 4x4 knowledge is based on owning a highly customizable 2012 rubicon. Most trucks with all wheel drive accomplish this be utilizing a center diff. I don't know much about this specific clutch mechanism in the Bighorn, Sport, or Laramie, however I do know that whatever it is, I don't like it and wish I didn't get the bighorn. I'm trying to figure out a way to get out and into a powerwagon. F THIS!
I did post in your other thread about the guy who says there is a kit coming to replace the clutch system with a mechanical one.Fair enough, whether a center different or clutch mechanism, it's inferior. My general 4x4 knowledge is based on owning a highly customizable 2012 rubicon. Most trucks with all wheel drive accomplish this be utilizing a center diff. I don't know much about this specific clutch mechanism in the Bighorn, Sport, or Laramie, however I do know that whatever it is, I don't like it and wish I didn't get the bighorn. I'm trying to figure out a way to get out and into a powerwagon. F THIS!
The only research that will reveal this issue is if you happen to find threads about it. Any official documentation from ram doesn't reveal the piece of crap they put in these trucks, only users can. It still isn't an excuse for ram misleading customers like they are.So you didn't do your research before you bought? Sorry you bought the wrong truck for your needs.
Don't beat yourself up. The GM auto trac transfer case has 4 auto and 4 hi/lock and it actually locks in 4 hi.I kinda agree with that for most people however I was coming out of a rubicon. I should have realized it as soon as I saw the auto 4wh knob setting. I didnt. I didn't realize actually until I went to almost thevery last page in the brochure where in very very small font it mentioned the difference. I already owned the truck at that point.
I know mine does regardless of what others "think" they know saying it doesn't fully lock in.Don't beat yourself up. The GM auto trac transfer case has 4 auto and 4 hi/lock and it actually locks in 4 hi.
That's a good possibility, but mine for sure locks at any speed. When I'm rolling through the pasture and hit a wet spot, it's hammer down.My guess is it's supposed to lock in, but the clutches slip under hard use. Some may be worse than others
