5.2 magnum turbo
dapepper9
Iowa/Nebraska Border
5.9L V8
$450 for device and canned tune. You don't need the custom boost stuff until you get it all together
e_hartzell17
e_hartzell17
Well I don't wanna buy the tuner unless I getting the custom tunes at the same time cuz turbo going on soon
e_hartzell17
e_hartzell17
Where exactly would I tap into to get oil to my turbo
e_hartzell17
e_hartzell17
Oil pressure sender. Just use a brass T fitting in the sender hole, install sender on top of T with turbo feed line on the side
Oh ok thank you
e_hartzell17
e_hartzell17
How do I wire the gym 2 bar map into my truck idk which wires go where
dapepper9
5.9L V8
They might be the same order. Colors look to be same order but that doesn't mean much.
Edit: ignore the arrow, just a generic photo from another thread. Arrow is pointing at TPS
e_hartzell17
e_hartzell17
And also what threads do I need to get to make an s bolt for my intake hat on my throttle body
e_hartzell17
e_hartzell17
There's 3 wires you need to match up. Ground wire is easy but I'm unsure if the order of the other 2
Ordered the bolt yesterday and it fits perfect but even with the rubber o ring in the intake hat it still leaks when I blow into it? Why?
e_hartzell17
e_hartzell17
Also I wanna put in my 39# injectors and 2 bar map to get a head start but I'm afraid of the motor running like crap with the map sensor and also afraid of washing cylinder walls what do y'all think would it be ok to do or not
dapepper9
5.9L V8
Very bad idea. Injectors and map are both a fairly easy swap but are both very much tied into the tuning
e_hartzell17
e_hartzell17
I would do it then then throw the tuner on but idk if it would work cause I don't have any boost
texasrebel
5.9 Magnum
Replying so I'll be able to find this easier later. Been meaning to read through this since you told me about it a while back.
Sent from my SAMSUNG-SM-G870A using Tapatalk
