SouthTexan your numbers are all screwed up.
How are my numbers screwed up? You stated that you tow a 5,000 lbs trailer and haul and 800 lb ATV, and the numbers for the trucks are from the article.
First off, the payload of those trucks is for 4x2's! Look at numbers for 4x4's and it's a different story.
Payload for an F150 crew cab 4x4 long bed start at 2,060 lbs and go up to 2,650 lbs for the HD F150. Payload for a Silverado or GMC crew cab 4x4 long bed starts at 2,060 lbs. You seem to be saying a lot of stuff that don't hold up to the facts.
Yes, the F150 is aluminum and one can get the higher gvw but it's still and ecoboost or 5.0. Not interested. I already mentioned all this.
Yes, but you said that none of those trucks in the review had enough payload for your 5,000 lb RV and 800 lb ATV. I was just showing that the Ford and GM trucks in the review actually did, even in their 4x4 variant.
The Toyota in the article is loaded crew cab 4x2. Looks like the do the same as RAM does. Spec out a 1500 with all the bling and you can get it down to less than 1000lbs payload. A 4x4 Double cab SR5 with 6.5' bed has a payload of 1620. More than the ram 1500 and Chevy by a 100lbs or so. To get the 6.2 in the chev you have to get the loaded truck.
Again, you just said that none of the trucks in that review had enough payload. I was just pointing out that they actually do have enough paylaod for your 5,000 lb RV, 800 lb ATV, and for the two passengers you would be able to fit in a regular cab since that is what you are getting.
Either way, for about the same $$ a guy can get into a 2500 RAM with about twice the payload capacity and either the 5.7 or the 6.4 and have a much more capable truck.
This is a false statement. As Drittal pointed out the 5.7L has a 9,000 lb GVWR and a starting payload of 2,650 lbs in a crew cab 4x4 long bed. That is exactly the same starting payload as a crew cab long bed 4x4 F150 HD. Although as I said earlier about three times, the Ram HD would handle the weight better while the F150 HD would perform better and get better MPG. Not even the 6.4L in the 2500 has twice the payload. I am not saying the F150 is better for you here, I am just saying that this statement false.
MPG's will be close enough to call even. I know guys with Tundras and ecoboosts and a chev 6.2 a couple years old. They all shrink to 8-10ish or up to 12 in certain conditions with a TT.
So does just about every other gas or diesel engine in certain conditions. It just depends if you are comparing apples to apples with those conditions.
