webdogg
- Aug 17, 2013
- 75
- 25
- 2014 CC Laramie Longhorn
- 6.4L Hemi
I also get the clunk on both sides of my truck with sudden drops. My old man has a '14 2500 CTD and has never experienced it.
I'll be the odd man out here and recommend you not go to a dealer again for the diff issue. here's why, and I mean no offense to any of the techs out there that work at a dealership:
Often the techs you get, as a lone consumer, are what would be thought of as the lowest common denominator. Dealerships are a "learning hospital". Not to say they are not smart and good at what they do- but they simply lack the experience required to properly service an item like a differential. There are shops that specialize in this day in and day out and they do it for a reason. The really experienced techs at the dealerships are almost ALWAYS overwhelmed with fleet service and repair because they are more experienced and more efficient and able to push work through at an alarming rate and that keeps the fleet guys happy. Happy fleet purchasers spend money.
I get that the dealer likely botched it to begin with, but at the end of the day- what is your time and frustration worth to you? I'd personally fork over the cash to a specialty shop to diagnose the issue properly and I would inquire about the cost to repair it properly. At least then you'd have some ammunition to take to the dealer. Were it me, I would just pony up and get it fixed right and move past it.
My tolerence fuse for dumb **** is really, really short. I go from calm to bat-**** crazy in about 7 seconds flat when people are trying to cover things up. I am of the schooling that if you don't know- just admit it and find out the right answer. It just sounds like you are getting the run around because nobody there knows what is wrong nor how to diagnose it correctly- and in that, I would be concerned about their ability to actually repair it correctly. Personally, my sanity and peace of mind is worth more than a thousand bucks or whatever it will be. It really sounds to me like the dealership is laying the foundation to brush you off.
EDIT: I might add that if you are completely fed up with the issue- raise **** with the manager and tell him or her you want the experienced tech to look at this instead of the line techs. You'd be surprised. A lot of things that are seemingly a mystery to most, these guys have seen a hundred times. I used to deal strictly with the old man at Ford all the time- called him tin-skin because he looked like tin man. Anyways, if I ever had a real spooky issue no one could figure out, I'd bet the old bugger a bottle of whiskey he wouldn't find it. In the 20 years until he passed away, I never collected a single bottle, but I sure paid a few out.
Please describe your rear end noise..mine is making a vibrating noise on takeoff that happens between say 1400 and 1700 rpms apprx. Dealer also said they have no clue what it could be but im going in for recall soon would like to get this taken care of then if possible
This is one of the best responses to a post I have ever read! Bravo!
To the OP, I would take his advice and save yourself the stress.
Ok i wasnt sure if there was a noise you heard before the diff leak was fixed..mine is not leaking but ive had the noise looked into before and its not the exhaust or any shields..id just hate to drive it till it breaks or suffers serious damage [emoji20]No mine is nothing like that. Mine is caused by incompetent techs that screwed it up when changing the pinion seal.
It starts at about 30mph through 43mph. Its a hawling/whining sound. Its speed dependent will do it in any gear and does it with light acceleration and deceleration. Im NOT able to hear it with heavy acceleration.
I think you are on to something with the body mounts. Mine did it on the driver's side today and that noise came from the floorboard area and I know there is a body mount right there.
I have great new guys.
I knew it, I told her!
She said they are going to replace the ring n pinion, carrier bearings, pinion bearings, crush sleeve, pinion seal, and pinion nut.
Anyway, I just wanted to share my good news update
I know what you mean! I hate having to bring it in. Technicians don't know crap about crap anymore. It's sad really!
I'm happy with my truck again. Makes me want to wash it now!
I don't know if I'd be making such a blanket statement like that. There's good techs and not so good techs, this is true every profession.
As for your situation with the diff, I'm glad they got it figured out. It's very likely that the housing had issues from the beginning. I've actually ran into this before, a Nitro got 3 sets of bearings in less than 30,000kms before warranty finally let us put a new housing in it, then magically everything was good. It can be a royal pain dealing with warranty and certain chrysler people, the majority of them don't have a clue how to diagnose an issue and won't let a tech do what they want to fix a vehicle. Sometimes it's like working with a hand tied behind your back.
