'96 ram hit varmit with driver side left tire..why does it pull to right?
Ramster96
5.2L
I hit medium sized varmit with left front tire and now ram pull hard to right? What happened?
Jeepwalker
WI
2012 Reg Cab, 4x4
There've been reports of guys hitting potholes and having the same issue ...going back years. Must have to do with the electric steering. I don't remember the 'fix'. Do a search (hit 'pothole'). You might try putting your truck wheels straight, unhook the battery for quite a while, then hook it back up. Must have been some varmit! ("Tell him about the twinky..." [Ghostbusters])
Maybe someone else will chime in.
_____
star_deceiver
Airdrie, Alberta
3.6 Pentastar
It’s very possible that said varmit has bent your tie-rod or damaged something inside the steering rack.
crazykid1994
Is your truck 2wd or 4wd. If it knocked the alignment off it’ll push the driver side tire out. For the truck to steer straight it’ll have to turn right slightly. Get the alignment checked. Unless it messed up the tire? Did it break the belt inside the tire?
_____
96 ram is hydraulic steering
chri5k
USA
Diesel
_____
Pretty sure a 96 didn't have electric steering.
Jeepwalker
WI
2012 Reg Cab, 4x4
Oh yeah.... I didn't see '96. Nope, no electric steering. Yeah probably alignment.
