A.C. Woes
MOPAR78
2014 Ram 1500 4x4
6.2 Demon
The condenser cooling fan finally went out. So I picked one up and went to change it but it's more involved. You have to disconect the condenser lines which means an evac and charge. What an engineering screw up!! Going to plan B....
MOPAR78
MOPAR78
2014 Ram 1500 4x4
6.2 Demon
Usually plan B is a trade in for a new one but not this time lol. She's a keeper. I'm looking into a second fan to mount in front of the condenser.
cheapbeater
Wisconsin
just cut the shroud where the condensor line goes through, then you can wiggle it out!! thats how i did mine. take a closer look at it, you'll see what i'm talking about...
MOPAR78
MOPAR78
2014 Ram 1500 4x4
6.2 Demon
Really? Did you take some pic's as where to cut it? Is it the Upper, lower or both line?
cheapbeater
Wisconsin
upper line, the shroud kind of juts out around the line if i remember, just cut that part off. i'll try to get you a pic tomorrow
RubberFrog
I thought our trucks had the kind of ac you could charge yourself?
MOPAR78
MOPAR78
2014 Ram 1500 4x4
6.2 Demon
Well I just tacked the project and won!! Thanks cheapbeater for the comment on that it can be done. Took a couple of hours to do but she's back together and working great!
MOPAR78
MOPAR78
2014 Ram 1500 4x4
6.2 Demon
(Sorry I missed this post)
You can, they have the ports, but I don't have the tool to pull the vacuum.
cheapbeater
Wisconsin
glad you got it done.. sorry i forgot about the pics, but i knew you could figure it out.
Shiloh 24
Kansas
5.9L gas
Our trucks have the standard 134a freeon ports, a low pressure and a high pressure side. The evac is not hard at all to do and a shop wouldn't charge you **** to do it, it's basically like a reverse air compressor that we hook up to our freeon gauges and draw until it pulls a vacuum and then recharge it after the work is done. Idk how much it would cost where your at but I could do it myself at the shop I work for for less than a hundred bucks easy.
rocket
Licensed Dynacologist
connecticut
was 2006
was a HEMI 5.7
shiloh he had a condensor fan that went as well. Btw. Really guy's
this thread is useless without pix's !!
ramhunter9
P-Star Jeep Wrangler
ya i replaced my fan as it was warped but the motor was good i bought a new fan and motor assy.... the old motor went to beater and he put her in .. not a bad job but ya some cutting was involved . glad you got it done bud
