ABS light but no code on OBD2 reader
g17jimmy
USA
The ABS light came on this morning, no other lights came on. I connected my ODB2 reader soon after the light came on and no codes were indicated. I searched here and on other forums but didn't see posts for this exact issue. Any ideas what is the likely issue?
Thanks
SYKRAMMAN
Banned
Jersey shore
06 Mega
Thanks
Thats weird, I've never seen that happen before. What kind of scanner do you have?
1500ram12
5.9L Cummins
You'll need a scanner that can connect to the abs module. Regular scanners only connect to the ecu for engine related problems. Most scanners that have the ability to connect to the abs module will run a couple hundred dollars.
2018 2500 6.4L Tradesman
HemiLonestar
MD
That^^ also true for airbag codes
WY-Dave
Cheyenne, WY
6.7 CTD
Three types of Readers
OBD
OBD+ABS
OBD+ABS+SRS
Island-cowboy
