Adding LED 3157 bulbs + Load Resistors - Need Help
I've looked for wiring diagram on here and im sure someone has said it before but i couldnt find anything with the search feature...
Vehicle Information:
2012 Dodge Ram Ext Cab Express 5.7 Hemi
Morimoto 50w 6k HIDs
Recon Third Brake Light
PlasmaGlow led lightbar for under tailgate - Bout to be uninstalled - Worthless *************
Stock Tail Lights - Candy Black Painted 6 layers with Clear coat
Right now I have a retro solution led side emitting bulb but it sucks...
Soo heres what my upgrade is going to be!
921 XP50 Cree Reverse Bulb - Shop DSK - Down South Kustoms
I know the reverse bulb doesn't require a resistor however I know the next upgrade does
3157 XP80 Cree Brake/Turn Signal Bulb - Shop DSK - Down South Kustoms
As well as a set of these 50w 6ohm resistors with quick splice connectors - Shop DSK - Down South Kustoms
So the question i have is ... Which wires do i splice into on my 12 dodge... I cant ever find a clear answer other then signal and ground line...... Colors? Any help is much appreciated
