Aftermarket Grill Help!
xXNotFBIXx
Michigan, USA
I’m looking to change out my basic stock grill for an aftermarket grill. I see such a huge difference of pricing and now I’m confused. I get that the super expensive ones are going to be so much better but are the “cheap” $200 garbage quality? Any advice or expertise is greatly appreciated.
I’ve been eye this one specifically and was wondering if anyone’s heard anything about this brand or price range. Is is going to fall apart a year from now?
EAG Replacement Front Grille Upper Grill - Charcoal Gray - with Amber LED Lights Fit for 13-18 Dodge Ram 1500 https://www.amazon.com/dp/B06XSR4NZC/ref=cm_sw_r_cp_api_glt_fabc_TM830MKK3F9T6D97PHZA?_encoding=UTF8&psc=1
Brandon-w
Yukon
2015 Ram 1500
Look up keb fab on Facebook he makes some pretty nice stuff.
Also didn't see you edited the original post. Link won't work.
Sent from my SM-G981W using Tapatalk
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
That is the going rate for that style there are a few a little cheaper on EBay and Amazon that are the same or similar styles.
Earlier rams Have a different shape grill so keep that in mind the bumpers were slightly different from 2009-2012
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
The EAG ones look very cheap in person ..... I have seen them discolored after a year to a dull light black almost grey .... get a mesh kind that you cut out the middle of your oem and spray the frame with raptor liner
Sent from my SM-T387V using Tapatalk
xXNotFBIXx
xXNotFBIXx
Michigan, USA
And that settles it! That’s what I’ll end up doing! Thank you!
2018 2wd
You can also find some already made on offerup that way you keep your current one .. I still have my original one, I bought another one with the honeycomb inserts and I sprayed it with raptor liner and I love the way it looks plus the rocks just bounce off lol
