- Aug 2, 2018
- 19,556
- 44,637
- Location
- Central Texas
- 2019 Bighorn, 4 X 4, 3.21 rear, Bright Flame Red Pearl Coat, Mopar tonneau cover,Westin Bed rug
- Hemi 5.7
Definitely has IBS, 2019 5th Gen 1500 Bighorn. NO not fail, but when the original battery was replaced with the 1st AGM, I had no knowledge of what/whateva the IBS done, so the charging rate was incorrect for the new battery. Did it kill it: doubt it. But with the new info: I was able to learn about it and "reset" it. Funny how sometimes U neva know about stuff till afta the fact: hate dat chit.
NO, nothing ref charging rate per se. The IBS integrates with like 4 modules, to include telling SOC of battery, temperature, load requirements, and passes this info to TIPM part (not sure which modules, that is beyond me), so the TIPM "tells" the alternator system the needed charging rate. When U put in new battery, all the info stored and communication with IBS is set in to whateva the old battery had/needed, not the new battery, so hence the "reset". A lot of brands, like BMW, Mercedes, even some Fords, U actually have to hook up to OBD and reset. On Rams, a lil different, IBS just needs to be off battery 2-4 hours (This according to tech).Wait, what? What is the point of a battery sensor if it doesn't sense the battery?
I replaced my OEM flooded wet cell battery with an AGM, are you saying my 2017 4th Gen Ram charging rate is also incorrect (too high) for an AGM battery?
How does one "reset" an IBS?
I've not, yet..but I will be doing this!Did you do the Big 3 wiring upgrade.If not,it makes quite a differance.
Big 3 upgrade adds power?
Hey guys, just put some wire together and installed my big 3 upgrade. Today I went for a ride and it felt like there was a very noticeable increase in power. Truck just pulls harder and smoother now... Is this just in my head or does the big 3 upgrade actually help with performance?www.ramforum.com
Thanks for the info (and reminder, too).
I had a full aftermarket grounding kit on my Acura TypeS and 300SRT8 back in the day and it appreciably helped the electrical system in each vehicle.
ADDED: PLS, nobody beat me up. Just relating what was told by tech, and no, he was not hitting me with a smoke b o m b.
I haven't read all 6 pages.Been running AGM batteries in my diesel for about 8 years. Optima redtops are the way to go in my opinion. Truck starts every time. Once the factory baytery goes in my hemi I'll put that in it too
Now dat I cannot help u on. Don’t u guys that do tunes and such have back ups for all yer tunes installed?JFC, Boird - you're a closet genius after all.
Well, I don't wanna have factory flash my ECM cause I got a tune bolted to it.
Tech seems to imply if you depower for hours the ECM goes into re-learn - can't believe it would just relearn the IBS part?
I wonder if my bolt on ECM tune would freak out?
Dang RAMS almost as bad. Even with straight vvt no e junkies I find if I let sit long time rolling the dice ref battery maintaining charge. I drive so little am thinking of installing NOCO maintainer lol.I haven't read all 6 pages.
I have two Mercedes that are two battery systems. One is for starting, and that's basically it. The other is a "systems" battery that is for all other functions. They are notorious for killing "systems" batteries if they aren't driven every day. On one when it went bad I bought the top of the line AutoZone battery. The thing didn't last 3 months. They replaced it, and that one went bad in a month. I am on my third one in a year. I decided when the second car needed it's systems battery replaced to get an Optima Yellow Top. I was only about $80 more than the AutoZone's. No problems, and it is a year old now.
I might add, both these cars are on battery maintainers.
can't have too many proper grounds for clean electricalCheck your stock power cable size 1st - turns out mine are 4/0 already, but I got a Heavy Duty 2500 and 6.4 Hemi.
I plant to check the routings this spring, however, to make sure they did the grounds correctly and didn't cheap out with not enough ground paths.
I've ran a lot of AGM batteries over the years, mostly as 'house' batteries for overland setups back before Lithium became economical and mainstream.
In my experience there's no advantage in AGM for a starting battery. Lead acid does a great job of delivering high current quickly and is the charging profile setup for OEM alternators. You will not charge an AGM correctly unless you have a DCDC system (i.e. RedArc) between the alternator and the battery, it's a different charging profile.
AGM's do have the advantage of being sealed and can work well in deep cycling applications like with running a trolling motor for long periods. But they don't make the best starting batteries. I know Optima has their different colors for different aplications, but Optima also has quality problems since they moved their manufacturing out of country.
IMO, the problem with lead acid isn't the battery type, it's the quality of battery chosen. The Ram vendor isn't the best. Go with something like a Napa Legend and you'll be happy. But no need to spend extra on the AGM for starting.
FYI I am a lot of things but:
1). Boird not live in closet nor have ever used except to store stuff and hang coats, lol
2). Definitely not genius kinda sorta make believe JOAT lmao
Did not say U did not have, U got it reversed reading something. Bet u a coke u got one. Take a picture of your battery top specifically negative side if U want I can see. Not on pc now so cannot see info thought u running 6.4 in 2500?Well yes, BUT - esp. for us older guys, tuning once was a royal PITA for me, and I don't wanna have to re-do it.
I'll ask my sons - maybe they know. A bunch of guys here might know, but I'd asked long ago about whether 2017 MY had a smart battery sensor and got zero responses.
You are the first guy to tell me it does NOT.
I don't think it hurts to add another piggyback 4G from the battery to fuse box though.Check your stock power cable size 1st - turns out mine are 4/0 already, but I got a Heavy Duty 2500 and 6.4 Hemi.
But see, what we're discussing today is vehicle batteries are way more than just starting batteries now. With scads of electronics, many that continue running in sleep mode, a tough battery that can take nonstop draw without draining excessively is critical now.
