- Dec 7, 2020
- 6,891
- 17,446
- Location
- Minneapolis, MN
- 2017 2500 Laramie Crew Cab
- 6.4L HEMI
Ok, this guy makes no sense:
"If you’ve just replaced the battery in your Ram 1500, then it’s important to reset the system so that everything runs efficiently. Fortunately, this can be done easily and quickly with a few simple steps. First, turn off all electronics – lights, audio systems and any other accessories.
Then open the hood and disconnect both negative (black) cables from the old battery. Next, connect one of these black cables to the new battery’s negative terminal and reattach all wires connected to it. Finally, reconnect both negative cables back onto their respective terminals on the battery and close up your hood."
This guy makes more sense:
This will allow your truck to reset itself and recognize the new battery.
2019 Ram 1500 Reset After Battery Change
The 2019 Ram 1500 is equipped with a computer system that must be reset after any battery changes. To do this, open the hood and locate the fuse box. Remove the IOD fuse from its slot and wait 10 seconds before replacing it in its original position.This will allow your truck to reset itself and recognize the new battery.
