Air in my steering?
Juvenator93
So a few weeks back while I was trying to chase down a steering clunk I took the cap off my steering reservoir to check if the level moved when I turned the wheel. I later noticed that I now have a sucking sound coming from my steering all the time. I also just this week noticed that if I'm holding the brakes I can't turn the whee all the way. The last quarter turn I have to let the brakes go to turn. Do I have air in my power steering?? dc89e4e173637dce4bd8347f86f8db50.jpg2015 Ram 2500 5.7 4x4
Ratket
Arizona-
That's odd- Hopefully someone with a little knowledge will chime in-
Rustycowl69
2001 ram 3500
V10
on my 01 3500, it doesn't have a vacuum booster for the power brakes. It uses power steering hydraulic pump to provide the power assist for brakes. Generically called hydroboost. Don't know if the 4th Gen have gone to that for their HD's. From your description it sounds like it.
Juvenator93
Juvenator93
I believe only the Cummins come equipped with a hydro booster
DannyMK2
Long Island, NY
2015 Power Wagon
you can try to purge air out the system if you think you may have some, but simply removing the cap wont introduce air to it if thats what your worried about.
Juvenator93
Juvenator93
Don't want to sound novice, but how would I do that exactly?
DannyMK2
Long Island, NY
2015 Power Wagon
remove the cap, make sure the reservoir is full, start the truck and turn the wheel from lock to lock a few times. top off fluid as needed. it makes it easier if you have the front tires off the ground.
Juvenator93
Juvenator93
Thanks for the help! I'll be doing that this weekend
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
To add to what Danny said, if you are sucking in air, the reservoir would also be showing a frothing or small bubbling in the fluid.
Juvenator93
Juvenator93
I'll have to take a look in the morning. Thanks for the help guys
JustinRam1500
