I am trying to figure out what the difference is between the AlphaRex Pro Series and Luxx headlights. Looking at their site I don't see anything explaining what it is. But there is a $300 upcharge for the Luxx.
Can someone help me with this?
Depends which set but for the most part the Pro series I just normal halogen bulbs in the halogen projector and the Luxx series is a fully built-in LED projector optimized for the led chips installed in it.
Pretty much this-
Pro: Generic Halogen projectors (decent quality, but not the best) with super cheap halogen bulbs. Rest of the headlight is top quality, led boards, wiring, plastics, all are top notch.
Luxx: AlphaRex developed their own patented projectors with built in LED chip boards and they modified and tuned the led chips and the projector lens until it was fully optimized and at its best output for the parts used. The output is really good. Rest of the lights are the same or similar to the Pro series.
I had a set of custom built AlphaRex Pro series lights where I opened them up and replaced the basic halogen projectors with 4 Morimoto D2S 4.0 projectors with custom fabricated mounting brackets with 4 full 5500k D2S hid kits and then modified the upper + lower DRL sections with RGB switchback leds and then custom painted the whole thing. I had a TON of money into those lights, around $2,000 without the labor or custom fabrication (which I did myself) and I ended up swapping them out for the Luxx version because the output of the Luxx was slightly less then the output of the 4 D2S projectors, but the ease of install and maintenance on the Luxx was 100x better then 4 hid kits so in the end I chose the Luxx lights over a fully built set of headlights.
You should get the Luxx or you will regret it later on. If you can’t afford the extra $300, just wait and save until you have it. It will be worth the wait. You won’t have to deal with trying to find a good LED/HID bulb and then having issues with the kits involved with them or bulbs blowing, trucks computer having issues, etc. the Luxx come with the led boards built into the projector and they come programmed to work out the box with the Rams tricky computer. Super easy install.
